23 #ifndef _RTEMS_PROFILING_H 24 #define _RTEMS_PROFILING_H 182 #define RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS 4 336 uint32_t indentation_level,
337 const char *indentation
uint32_t processor_index
The processor index of this profiling data.
Definition: profiling.h:108
rtems_profiling_header header
The profiling data header.
Definition: profiling.h:206
uint32_t max_interrupt_time
The maximum time spent to process a single sequence of nested interrupts in nanoseconds.
Definition: profiling.h:158
uint32_t max_acquire_time
The maximum lock acquire time in nanoseconds.
Definition: profiling.h:216
SMP lock profiling data.
Definition: profiling.h:202
Type of per-CPU profiling data.
Definition: profiling.h:69
rtems_profiling_smp_lock smp_lock
SMP lock profiling data if indicated by the header.
Definition: profiling.h:281
uint64_t thread_dispatch_disabled_count
Count of times when the thread dispatch disable level changes from zero to one in thread context...
Definition: profiling.h:121
uint32_t max_interrupt_delay
The maximum interrupt delay in nanoseconds if supported by the hardware.
Definition: profiling.h:146
uint64_t total_section_time
Total lock section time in nanoseconds.
Definition: profiling.h:249
uint32_t max_thread_dispatch_disabled_time
The maximum time of disabled thread dispatching in nanoseconds.
Definition: profiling.h:113
int(* rtems_profiling_printf)(void *arg, const char *format,...)
Function for formatted output.
Definition: profiling.h:319
const char * name
The lock name.
Definition: profiling.h:211
Collection of profiling data.
Definition: profiling.h:267
Count of lock contention counters for SMP lock profiling.
Definition: profiling.h:182
Header to specify the actual profiling data.
Definition: profiling.h:271
uint64_t total_interrupt_time
Total time of interrupt processing in nanoseconds.
Definition: profiling.h:176
void rtems_profiling_iterate(rtems_profiling_visitor visitor, void *visitor_arg)
Iterates through all profiling data of the system.
Definition: profilingiterate.c:142
void(* rtems_profiling_visitor)(void *arg, const rtems_profiling_data *data)
Visitor function for the profiling iteration.
Definition: profiling.h:292
Definition: profiling.h:103
Per-CPU profiling data.
Definition: profiling.h:99
uint64_t total_acquire_time
Total lock acquire time in nanoseconds.
Definition: profiling.h:239
int rtems_profiling_report_xml(const char *name, rtems_profiling_printf printf_func, void *printf_arg, uint32_t indentation_level, const char *indentation)
Reports profiling data as XML.
Definition: profilingreportxml.c:278
uint64_t total_thread_dispatch_disabled_time
Total time of disabled thread dispatching in nanoseconds.
Definition: profiling.h:132
uint64_t interrupt_count
Count of times when the interrupt nest level changes from zero to one.
Definition: profiling.h:166
rtems_profiling_per_cpu per_cpu
Per-CPU profiling data if indicated by the header.
Definition: profiling.h:276
uint64_t usage_count
The count of lock uses.
Definition: profiling.h:228
Type of SMP lock profiling data.
Definition: profiling.h:76
uint32_t max_section_time
The maximum lock section time in nanoseconds.
Definition: profiling.h:221
rtems_profiling_type
Type of profiling data.
Definition: profiling.h:63
