#define | RTEMS_PPPD_LINKUP_HOOK 1 |
#define | RTEMS_PPPD_LINKDOWN_HOOK 2 |
#define | RTEMS_PPPD_IPUP_HOOK 3 |
#define | RTEMS_PPPD_IPDOWN_HOOK 4 |
#define | RTEMS_PPPD_ERROR_HOOK 5 |
#define | RTEMS_PPPD_EXIT_HOOK 6 |
typedef void(* | rtems_pppd_hookfunction) (void) |
typedef int(* | rtems_pppd_dialerfunction) (int tty, int mode, char *pScript) |
int | rtems_pppd_initialize (void) |
int | rtems_pppd_terminate (void) |
int | rtems_pppd_reset_options (void) |
int | rtems_pppd_set_hook (int id, rtems_pppd_hookfunction hookfp) |
int | rtems_pppd_set_dialer (rtems_pppd_dialerfunction dialerfp) |
int | rtems_pppd_set_option (const char *pOption, const char *pValue) |
int | rtems_pppd_connect (void) |
int | rtems_pppd_disconnect (void) |
int | rtems_ppp_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
