rtems-4.11.3
libnetworking
arpa
nameser_compat.h
1
/* Copyright (c) 1983, 1989
2
* The Regents of the University of California. All rights reserved.
3
4
5
* modification, are permitted provided that the following conditions
6
* are met:
7
* 1. Redistributions of source code must retain the above copyright
8
* notice, this list of conditions and the following disclaimer.
9
* 2. Redistributions in binary form must reproduce the above copyright
10
* notice, this list of conditions and the following disclaimer in the
11
* documentation and/or other materials provided with the distribution.
12
* 3. All advertising materials mentioning features or use of this software
13
* must display the following acknowledgement:
14
* This product includes software developed by the University of
15
* California, Berkeley and its contributors.
16
* 4. Neither the name of the University nor the names of its contributors
17
* may be used to endorse or promote products derived from this software
18
* without specific prior written permission.
19
20
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
21
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
24
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
25
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
26
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
27
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
28
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
29
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
30
* SUCH DAMAGE.
31
32
33
34
* from nameser.h 8.1 (Berkeley) 6/2/93
35
* From: Id: nameser_compat.h,v 8.9 1998/03/20 23:25:10 halley Exp
36
37
38
#ifndef _ARPA_NAMESER_COMPAT_
39
#define _ARPA_NAMESER_COMPAT_
40
41
#define __BIND 19950621
/* (DEAD) interface version stamp. */
42
43
rtems/endian.h
44
45
#if !defined(BYTE_ORDER) || \
46
(BYTE_ORDER != BIG_ENDIAN && BYTE_ORDER != LITTLE_ENDIAN && \
47
BYTE_ORDER != PDP_ENDIAN)
48
/* you must determine what the correct bit order is for
49
* your compiler - the next line is an intentional error
50
* which will force your compiles to bomb until you fix
51
* the above macros.
52
53
error
"Undefined or invalid BYTE_ORDER"
54
#endif
55
56
57
* Structure for query header. The order of the fields is machine- and
58
* compiler-dependent, depending on the byte/bit order and the layout
59
* of bit fields. We use bit fields only in int variables, as this
60
* is all ANSI requires. This requires a somewhat confusing rearrangement.
61
62
63
typedef
struct
64
unsigned
/* query identification number */
65
#if BYTE_ORDER == BIG_ENDIAN
66
/* fields in third byte */
67
unsigned
qr: 1;
/* response flag */
68
unsigned
opcode: 4;
/* purpose of message */
69
unsigned
aa: 1;
/* authoritive answer */
70
unsigned
tc: 1;
/* truncated message */
71
unsigned
rd: 1;
/* recursion desired */
72
/* fields in fourth byte */
73
unsigned
ra: 1;
/* recursion available */
74
unsigned
unused :1;
/* unused bits (MBZ as of 4.9.3a3) */
75
unsigned
ad: 1;
/* authentic data from named */
76
unsigned
cd: 1;
/* checking disabled by resolver */
77
unsigned
rcode :4;
/* response code */
78
#endif
79
#if BYTE_ORDER == LITTLE_ENDIAN || BYTE_ORDER == PDP_ENDIAN
80
81
unsigned
rd :1;
82
unsigned
tc :1;
83
unsigned
aa :1;
84
unsigned
opcode :4;
85
unsigned
qr :1;
/* response flag */
86
87
unsigned
rcode :4;
/* response code */
88
unsigned
cd: 1;
89
unsigned
ad: 1;
90
unsigned
unused :1;
91
unsigned
ra :1;
92
#endif
93
/* remaining bytes */
94
unsigned
qdcount :16;
/* number of question entries */
95
unsigned
ancount :16;
/* number of answer entries */
96
unsigned
nscount :16;
/* number of authority entries */
97
unsigned
arcount :16;
/* number of resource entries */
98
HEADER
99
100
#define PACKETSZ NS_PACKETSZ
101
#define MAXDNAME NS_MAXDNAME
102
#define MAXCDNAME NS_MAXCDNAME
103
#define MAXLABEL NS_MAXLABEL
104
#define HFIXEDSZ NS_HFIXEDSZ
105
#define QFIXEDSZ NS_QFIXEDSZ
106
#define RRFIXEDSZ NS_RRFIXEDSZ
107
#define INT32SZ NS_INT32SZ
108
#define INT16SZ NS_INT16SZ
109
#define INADDRSZ NS_INADDRSZ
110
#define IN6ADDRSZ NS_IN6ADDRSZ
111
#define INDIR_MASK NS_CMPRSFLGS
112
#define NAMESERVER_PORT NS_DEFAULTPORT
113
114
#define S_ZONE ns_s_zn
115
#define S_PREREQ ns_s_pr
116
#define S_UPDATE ns_s_ud
117
#define S_ADDT ns_s_ar
118
119
#define QUERY ns_o_query
120
#define IQUERY ns_o_iquery
121
#define STATUS ns_o_status
122
#define NS_NOTIFY_OP ns_o_notify
123
#define NS_UPDATE_OP ns_o_update
124
125
#define NOERROR ns_r_noerror
126
#define FORMERR ns_r_formerr
127
#define SERVFAIL ns_r_servfail
128
#define NXDOMAIN ns_r_nxdomain
129
#define NOTIMP ns_r_notimpl
130
#define REFUSED ns_r_refused
131
#define YXDOMAIN ns_r_yxdomain
132
#define YXRRSET ns_r_yxrrset
133
#define NXRRSET ns_r_nxrrset
134
#define NOTAUTH ns_r_notauth
135
#define NOTZONE ns_r_notzone
136
137
#define DELETE ns_uop_delete
138
#define ADD ns_uop_add
139
140
#define T_A ns_t_a
141
#define T_NS ns_t_ns
142
#define T_MD ns_t_md
143
#define T_MF ns_t_mf
144
#define T_CNAME ns_t_cname
145
#define T_SOA ns_t_soa
146
#define T_MB ns_t_mb
147
#define T_MG ns_t_mg
148
#define T_MR ns_t_mr
149
#define T_NULL ns_t_null
150
#define T_WKS ns_t_wks
151
#define T_PTR ns_t_ptr
152
#define T_HINFO ns_t_hinfo
153
#define T_MINFO ns_t_minfo
154
#define T_MX ns_t_mx
155
#define T_TXT ns_t_txt
156
#define T_RP ns_t_rp
157
#define T_AFSDB ns_t_afsdb
158
#define T_X25 ns_t_x25
159
#define T_ISDN ns_t_isdn
160
#define T_RT ns_t_rt
161
#define T_NSAP ns_t_nsap
162
#define T_NSAP_PTR ns_t_nsap_ptr
163
#define T_SIG ns_t_sig
164
#define T_KEY ns_t_key
165
#define T_PX ns_t_px
166
#define T_GPOS ns_t_gpos
167
#define T_AAAA ns_t_aaaa
168
#define T_LOC ns_t_loc
169
#define T_NXT ns_t_nxt
170
#define T_EID ns_t_eid
171
#define T_NIMLOC ns_t_nimloc
172
#define T_SRV ns_t_srv
173
#define T_ATMA ns_t_atma
174
#define T_NAPTR ns_t_naptr
175
#define T_IXFR ns_t_ixfr
176
#define T_AXFR ns_t_axfr
177
#define T_MAILB ns_t_mailb
178
#define T_MAILA ns_t_maila
179
#define T_ANY ns_t_any
180
181
#define C_IN ns_c_in
182
#define C_CHAOS ns_c_chaos
183
#define C_HS ns_c_hs
184
/* BIND_UPDATE */
185
#define C_NONE ns_c_none
186
#define C_ANY ns_c_any
187
188
#define GETSHORT NS_GET16
189
#define GETLONG NS_GET32
190
#define PUTSHORT NS_PUT16
191
#define PUTLONG NS_PUT32
192
193
#endif
/* _ARPA_NAMESER_COMPAT_ */
HEADER
Definition:
nameser_compat.h:64
endian.h
This include file provides endian information about the target.
