#include <errno.h>#include <stdio.h>#include <string.h>#include <sys/stat.h>#include <sys/types.h>#include <fcntl.h>#include <unistd.h>#include <sys/socket.h>#include <netinet/in.h>#include <arpa/inet.h>#include <rtems/mkrootfs.h>#include <rtems/libio.h>
| struct | rtems_rootfs_dir_table |
| #define | MKFILE_MODE (S_IRUSR | S_IWUSR | S_IWGRP | S_IRGRP | S_IROTH) |
| #define | MKDIR_MODE (S_IRWXU | S_IRGRP | S_IXGRP | S_IROTH | S_IXOTH) |
Typedefs | |
| typedef struct rtems_rootfs_dir_table | rtems_rootfs_dir_table |
| int | rtems_rootfs_file_append (const char *file, mode_t omode, const int line_cnt, const char **lines) |
| Appends the lines to the a file. More... | |
| int | rtems_rootfs_append_host_rec (in_addr_t cip, const char *cname, const char *dname) |
| Helper for bulding an /etc/hosts file. More... | |
| int | rtems_create_root_fs (void) |
| Create a few common directories, plus a: /etc/passwd, /etc/group, /etc/host.conf, and /etc/hosts file. More... | |
| int rtems_create_root_fs | ( | void | ) |
| int rtems_rootfs_append_host_rec | ( | in_addr_t | cip, |
| const char * | cname, | ||
| const char * | dname | ||
| cip | |
| cname | |
| dname |
| int rtems_rootfs_file_append | ( | const char * | file, |
| mode_t | omode, | ||
| const int | line_cnt, | ||
| const char ** | lines | ||
Create the file and builds the path if it does not exist.
| file | |
| omode | |
| line_cnt | |
| lines |
