rtems-4.11.3
libnetworking
netinet
ip_icmp.h
1
2
* Copyright (c) 1982, 1986, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)ip_icmp.h 8.1 (Berkeley) 6/10/93
30
* $FreeBSD: src/sys/netinet/ip_icmp.h,v 1.26 2005/05/04 13:09:19 andre Exp $
31
32
33
34
#ifndef _NETINET_IP_ICMP_H_
35
#define _NETINET_IP_ICMP_H_
36
37
netinet/in.h
/* struct in_addr */
38
netinet/ip.h
/* struct ip */
39
40
41
* Interface Control Message Protocol Definitions.
42
* Per RFC 792, September 1981.
43
44
45
46
* Internal of an ICMP Router Advertisement
47
48
struct
icmp_ra_addr
49
u_int32_t ira_addr;
50
u_int32_t ira_preference;
51
52
53
54
* Structure of an icmp header.
55
56
struct
icmp
57
u_char icmp_type;
/* type of message, see below */
58
u_char icmp_code;
/* type sub code */
59
u_short icmp_cksum;
/* ones complement cksum of struct */
60
union
61
u_char ih_pptr;
/* ICMP_PARAMPROB */
62
struct
in_addr
ih_gwaddr;
/* ICMP_REDIRECT */
63
struct
ih_idseq {
64
uint16_t icd_id;
/* network format */
65
uint16_t icd_seq;
66
} ih_idseq;
67
int
ih_void;
68
69
/* ICMP_UNREACH_NEEDFRAG -- Path MTU Discovery (RFC1191) */
70
struct
ih_pmtu {
71
uint16_t ipm_void;
72
uint16_t ipm_nextmtu;
73
} ih_pmtu;
74
75
struct
ih_rtradv {
76
u_char irt_num_addrs;
77
u_char irt_wpa;
78
u_int16_t irt_lifetime;
79
} ih_rtradv;
80
} icmp_hun;
81
#define icmp_pptr icmp_hun.ih_pptr
82
#define icmp_gwaddr icmp_hun.ih_gwaddr
83
#define icmp_id icmp_hun.ih_idseq.icd_id
84
#define icmp_seq icmp_hun.ih_idseq.icd_seq
85
#define icmp_void icmp_hun.ih_void
86
#define icmp_pmvoid icmp_hun.ih_pmtu.ipm_void
87
#define icmp_nextmtu icmp_hun.ih_pmtu.ipm_nextmtu
88
#define icmp_num_addrs icmp_hun.ih_rtradv.irt_num_addrs
89
#define icmp_wpa icmp_hun.ih_rtradv.irt_wpa
90
#define icmp_lifetime icmp_hun.ih_rtradv.irt_lifetime
91
union
92
struct
id_ts {
/* ICMP Timestamp */
93
94
* The next 3 fields are in network format,
95
* milliseconds since 00:00 GMT
96
97
uint32_t its_otime;
/* Originate */
98
uint32_t its_rtime;
/* Receive */
99
uint32_t its_ttime;
/* Transmit */
100
} id_ts;
101
struct
id_ip {
102
struct
ip
idi_ip;
103
/* options and then 64 bits of data */
104
} id_ip;
105
struct
icmp_ra_addr
id_radv;
106
u_int32_t id_mask;
107
char
id_data[1];
108
} icmp_dun;
109
#define icmp_otime icmp_dun.id_ts.its_otime
110
#define icmp_rtime icmp_dun.id_ts.its_rtime
111
#define icmp_ttime icmp_dun.id_ts.its_ttime
112
#define icmp_ip icmp_dun.id_ip.idi_ip
113
#define icmp_radv icmp_dun.id_radv
114
#define icmp_mask icmp_dun.id_mask
115
#define icmp_data icmp_dun.id_data
116
117
118
119
* Lower bounds on packet lengths for various types.
120
* For the error advice packets must first insure that the
121
* packet is large enough to contain the returned ip header.
122
* Only then can we do the check to see if 64 bits of packet
123
* data have been returned, since we need to check the returned
124
* ip header length.
125
126
#define ICMP_MINLEN 8
/* abs minimum */
127
#define ICMP_TSLEN (8 + 3 * sizeof (uint32_t))
/* timestamp */
128
#define ICMP_MASKLEN 12
/* address mask */
129
#define ICMP_ADVLENMIN (8 + sizeof (struct ip) + 8)
/* min */
130
#ifndef _IP_VHL
131
#define ICMP_ADVLEN(p) (8 + ((p)->icmp_ip.ip_hl << 2) + 8)
132
/* N.B.: must separately check that ip_hl >= 5 */
133
#else
134
#define ICMP_ADVLEN(p) (8 + (IP_VHL_HL((p)->icmp_ip.ip_vhl) << 2) + 8)
135
/* N.B.: must separately check that header length >= 5 */
136
#endif
137
138
139
* Definition of type and code field values.
140
141
#define ICMP_ECHOREPLY 0
/* echo reply */
142
#define ICMP_UNREACH 3
/* dest unreachable, codes: */
143
#define ICMP_UNREACH_NET 0
/* bad net */
144
#define ICMP_UNREACH_HOST 1
/* bad host */
145
#define ICMP_UNREACH_PROTOCOL 2
/* bad protocol */
146
#define ICMP_UNREACH_PORT 3
/* bad port */
147
#define ICMP_UNREACH_NEEDFRAG 4
/* IP_DF caused drop */
148
#define ICMP_UNREACH_SRCFAIL 5
/* src route failed */
149
#define ICMP_UNREACH_NET_UNKNOWN 6
/* unknown net */
150
#define ICMP_UNREACH_HOST_UNKNOWN 7
/* unknown host */
151
#define ICMP_UNREACH_ISOLATED 8
/* src host isolated */
152
#define ICMP_UNREACH_NET_PROHIB 9
/* prohibited access */
153
#define ICMP_UNREACH_HOST_PROHIB 10
/* ditto */
154
#define ICMP_UNREACH_TOSNET 11
/* bad tos for net */
155
#define ICMP_UNREACH_TOSHOST 12
/* bad tos for host */
156
#define ICMP_UNREACH_FILTER_PROHIB 13
/* admin prohib */
157
#define ICMP_UNREACH_HOST_PRECEDENCE 14
/* host prec vio. */
158
#define ICMP_UNREACH_PRECEDENCE_CUTOFF 15
/* prec cutoff */
159
#define ICMP_SOURCEQUENCH 4
/* packet lost, slow down */
160
#define ICMP_REDIRECT 5
/* shorter route, codes: */
161
#define ICMP_REDIRECT_NET 0
/* for network */
162
#define ICMP_REDIRECT_HOST 1
/* for host */
163
#define ICMP_REDIRECT_TOSNET 2
/* for tos and net */
164
#define ICMP_REDIRECT_TOSHOST 3
/* for tos and host */
165
#define ICMP_ALTHOSTADDR 6
/* alternate host address */
166
#define ICMP_ECHO 8
/* echo service */
167
#define ICMP_ROUTERADVERT 9
/* router advertisement */
168
#define ICMP_ROUTERADVERT_NORMAL 0
/* normal advertisement */
169
#define ICMP_ROUTERADVERT_NOROUTE_COMMON 16
/* selective routing */
170
#define ICMP_ROUTERSOLICIT 10
/* router solicitation */
171
#define ICMP_TIMXCEED 11
/* time exceeded, code: */
172
#define ICMP_TIMXCEED_INTRANS 0
/* ttl==0 in transit */
173
#define ICMP_TIMXCEED_REASS 1
/* ttl==0 in reass */
174
#define ICMP_PARAMPROB 12
/* ip header bad */
175
#define ICMP_PARAMPROB_ERRATPTR 0
/* error at param ptr */
176
#define ICMP_PARAMPROB_OPTABSENT 1
/* req. opt. absent */
177
#define ICMP_PARAMPROB_LENGTH 2
/* bad length */
178
#define ICMP_TSTAMP 13
/* timestamp request */
179
#define ICMP_TSTAMPREPLY 14
/* timestamp reply */
180
#define ICMP_IREQ 15
/* information request */
181
#define ICMP_IREQREPLY 16
/* information reply */
182
#define ICMP_MASKREQ 17
/* address mask request */
183
#define ICMP_MASKREPLY 18
/* address mask reply */
184
#define ICMP_TRACEROUTE 30
/* traceroute */
185
#define ICMP_DATACONVERR 31
/* data conversion error */
186
#define ICMP_MOBILE_REDIRECT 32
/* mobile host redirect */
187
#define ICMP_IPV6_WHEREAREYOU 33
/* IPv6 where-are-you */
188
#define ICMP_IPV6_IAMHERE 34
/* IPv6 i-am-here */
189
#define ICMP_MOBILE_REGREQUEST 35
/* mobile registration req */
190
#define ICMP_MOBILE_REGREPLY 36
/* mobile registration reply */
191
#define ICMP_SKIP 39
/* SKIP */
192
#define ICMP_PHOTURIS 40
/* Photuris */
193
#define ICMP_PHOTURIS_UNKNOWN_INDEX 1
/* unknown sec index */
194
#define ICMP_PHOTURIS_AUTH_FAILED 2
/* auth failed */
195
#define ICMP_PHOTURIS_DECRYPT_FAILED 3
/* decrypt failed */
196
197
#define ICMP_MAXTYPE 40
198
199
#define ICMP_INFOTYPE(type) \
200
((type) == ICMP_ECHOREPLY || (type) == ICMP_ECHO || \
201
(type) == ICMP_ROUTERADVERT || (type) == ICMP_ROUTERSOLICIT || \
202
(type) == ICMP_TSTAMP || (type) == ICMP_TSTAMPREPLY || \
203
(type) == ICMP_IREQ || (type) == ICMP_IREQREPLY || \
204
(type) == ICMP_MASKREQ || (type) == ICMP_MASKREPLY)
205
206
#ifdef _KERNEL
207
void
icmp_error(
struct
mbuf
int
int
, n_long,
struct
ifnet
208
void
icmp_input(
struct
mbuf
int
209
int
ip_next_mtu(
int
int
210
#endif
211
212
#endif
icmp_ra_addr
Definition:
ip_icmp.h:49
ip.h
in.h
icmp
Definition:
ip_icmp.h:57
ip
Definition:
ip.h:61
in_addr
Definition:
inet.h:93
ifnet
Definition:
if_var.h:99
mbuf
Definition:
mbuf.h:103
