rtems-4.11.3
score
cpu
avr
avr
iotn13.h
1
11
12
* Copyright (c) 2004, Theodore A. Roth
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* * Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
21
* * Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in
23
* the documentation and/or other materials provided with the
24
* distribution.
25
26
* * Neither the name of the copyright holders nor the names of
27
* contributors may be used to endorse or promote products derived
28
* from this software without specific prior written permission.
29
30
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
31
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
32
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
33
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
34
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
35
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
36
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
37
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
38
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
39
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
40
* POSSIBILITY OF SUCH DAMAGE.
41
42
43
#ifndef _AVR_IOTN13_H_
44
#define _AVR_IOTN13_H_ 1
45
53
#ifndef _AVR_IO_H_
54
# error "Include <avr/io.h> instead of this file."
55
#endif
56
57
#ifndef _AVR_IOXXX_H_
58
# define _AVR_IOXXX_H_ "iotn13.h"
59
#else
60
# error "Attempt to include more than one <avr/ioXXX.h> file."
61
#endif
62
63
/* I/O registers and bit names */
64
65
/* ADC Control and Status Register B */
66
#define ADCSRB _SFR_IO8(0x03)
67
# define ACME 6
68
# define ADTS2 2
69
# define ADTS1 1
70
# define ADTS0 0
71
72
/* ADC Data Register */
73
#ifndef __ASSEMBLER__
74
#define ADC _SFR_IO16 (0x04)
75
#endif
76
#define ADCW _SFR_IO16 (0x04)
77
#define ADCL _SFR_IO8(0x04)
78
#define ADCH _SFR_IO8(0x05)
79
80
/* ADC Control and Status Register A */
81
#define ADCSRA _SFR_IO8(0x06)
82
# define ADEN 7
83
# define ADSC 6
84
# define ADATE 5
85
# define ADIF 4
86
# define ADIE 3
87
# define ADPS2 2
88
# define ADPS1 1
89
# define ADPS0 0
90
91
/* ADC Multiplex Selection Register */
92
#define ADMUX _SFR_IO8(0x07)
93
# define REFS0 6
94
# define ADLAR 5
95
# define MUX1 1
96
# define MUX0 0
97
98
/* Analog Comparator Control and Status Register */
99
#define ACSR _SFR_IO8(0x08)
100
# define ACD 7
101
# define ACBG 6
102
# define ACO 5
103
# define ACI 4
104
# define ACIE 3
105
# define ACIS1 1
106
# define ACIS0 0
107
108
/* Digital Input Disable Register 0 */
109
#define DIDR0 _SFR_IO8(0x14)
110
# define ADC0D 5
111
# define ADC2D 4
112
# define ADC3D 3
113
# define ADC1D 2
114
# define AIN1D 1
115
# define AIN0D 0
116
117
/* PIN Change Mask Register */
118
#define PCMSK _SFR_IO8(0x15)
119
# define PCINT5 5
120
# define PCINT4 4
121
# define PCINT3 3
122
# define PCINT2 2
123
# define PCINT1 1
124
# define PCINT0 0
125
126
/* Port B Pin Utilization [2535D-AVR-04/04]
127
- PORTB5 = PCINT5/RESET#/ADC0/dW
128
- PORTB4 = PCINT4/ADC2
129
- PORTB3 = PCINT3/CLKI/ADC3
130
- PORTB2 = SCK/ADC1/T0/PCINT2
131
- PORTB1 = MISO/AIN1/OC0B/INT0/PCINT1
132
- PORTB0 = MOSI/AIN0/OC0A/PCINT0 */
133
134
/* Input Pins, Port B */
135
#define PINB _SFR_IO8(0x16)
136
# define PINB5 5
137
# define PINB4 4
138
# define PINB3 3
139
# define PINB2 2
140
# define PINB1 1
141
# define PINB0 0
142
143
/* Data Direction Register, Port B */
144
#define DDRB _SFR_IO8(0x17)
145
# define DDB5 5
146
# define DDB4 4
147
# define DDB3 3
148
# define DDB2 2
149
# define DDB1 1
150
# define DDB0 0
151
152
/* Data Register, Port B */
153
#define PORTB _SFR_IO8(0x18)
154
# define PB5 5
155
# define PB4 4
156
# define PB3 3
157
# define PB2 2
158
# define PB1 1
159
# define PB0 0
160
161
/* ATtiny EEPROM Control Register EECR */
162
#define EECR _SFR_IO8(0x1C)
163
#define EEPM1 5
164
#define EEPM0 4
165
#define EERIE 3
166
#define EEMPE 2
167
#define EEPE 1
168
#define EERE 0
169
170
/* EEPROM Data Register */
171
#define EEDR _SFR_IO8(0x1D)
172
173
/* The EEPROM Address Register EEAR[6:0] */
174
#define EEAR _SFR_IO8(0x1E)
175
#define EEARL _SFR_IO8(0x1E)
176
177
/* Watchdog Timer Control Register */
178
#define WDTCR _SFR_IO8(0x21)
179
# define WDTIF 7
180
# define WDTIE 6
181
# define WDP3 5
182
# define WDCE 4
183
# define WDE 3
184
# define WDP2 2
185
# define WDP1 1
186
# define WDP0 0
187
188
/* Clock Prescale Register */
189
#define CLKPR _SFR_IO8(0x26)
190
# define CLKPCE 7
191
# define CLKPS3 3
192
# define CLKPS2 2
193
# define CLKPS1 1
194
# define CLKPS0 0
195
196
/* General Timer/Counter Control Register */
197
#define GTCCR _SFR_IO8(0x28)
198
# define TSM 7
199
# define PSR10 0
200
201
/* Output Compare 0 Register B */
202
#define OCR0B _SFR_IO8(0x29)
203
204
/* debugWIRE Data Register */
205
#define DWDR _SFR_IO8(0x2e)
206
207
/* Timer/Counter 0 Control Register A */
208
#define TCCR0A _SFR_IO8(0x2f)
209
# define COM0A1 7
210
# define COM0A0 6
211
# define COM0B1 5
212
# define COM0B0 4
213
# define WGM01 1
214
# define WGM00 0
215
216
/* Oscillator Calibration Register */
217
#define OSCCAL _SFR_IO8(0x31)
218
219
/* Timer/Counter0 (8-bit) */
220
#define TCNT0 _SFR_IO8(0x32)
221
222
/* Timer/Counter 0 Control Register B */
223
#define TCCR0B _SFR_IO8(0x33)
224
# define FOC0A 7
225
# define FOC0B 6
226
# define WGM02 3
227
# define CS02 2
228
# define CS01 1
229
# define CS00 0
230
231
/* MCU General Status Register */
232
#define MCUSR _SFR_IO8(0x34)
233
# define WDRF 3
234
# define BORF 2
235
# define EXTRF 1
236
# define PORF 0
237
238
/* MCU General Control Register */
239
#define MCUCR _SFR_IO8(0x35)
240
# define PUD 6
241
# define SE 5
242
# define SM1 4
243
# define SM0 3
244
# define ISC01 1
245
# define ISC00 0
246
247
/* Output Compare 0 REgister A */
248
#define OCR0A _SFR_IO8(0x36)
249
250
/* Store Program Memory Control and Status Register */
251
#define SPMCSR _SFR_IO8(0x37)
252
# define CTPB 4
253
# define RFLB 3
254
# define PGWRT 2
255
# define PGERS 1
256
# define SPMEN 0
257
# define SELFPRGEN 0
258
259
/* Timer/Counter 0 Interrupt Flag Register */
260
#define TIFR0 _SFR_IO8(0x38)
261
# define OCF0B 3
262
# define OCF0A 2
263
# define TOV0 1
264
265
/* Timer/Counter 0 Interrupt MaSK Register */
266
#define TIMSK0 _SFR_IO8(0x39)
267
# define OCIE0B 3
268
# define OCIE0A 2
269
# define TOIE0 1
270
271
/* General Interrupt Flag Register */
272
#define GIFR _SFR_IO8(0x3a)
273
# define INTF0 6
274
# define PCIF 5
275
276
/* General Interrupt MaSK register */
277
#define GIMSK _SFR_IO8(0x3b)
278
# define INT0 6
279
# define PCIE 5
280
281
/* SPL and SREG are defined in <avr/io.h> */
282
283
/* From the datasheet:
284
1 0x0000 RESET External Pin, Power-on Reset, Brown-out Reset, Watchdog Reset
285
2 0x0001 INT0 External Interrupt Request 0
286
3 0x0002 PCINT0 Pin Change Interrupt Request 0
287
4 0x0003 TIM0_OVF Timer/Counter Overflow
288
5 0x0004 EE_RDY EEPROM Ready
289
6 0x0005 ANA_COMP Analog Comparator
290
7 0x0006 TIM0_COMPA Timer/Counter Compare Match A
291
8 0x0007 TIM0_COMPB Timer/Counter Compare Match B
292
9 0x0008 WDT Watchdog Time-out
293
10 0x0009 ADC ADC Conversion Complete */
294
295
/* External Interrupt 0 */
296
#define INT0_vect _VECTOR(1)
297
#define SIG_INTERRUPT0 _VECTOR(1)
298
299
/* External Interrupt Request 0 */
300
#define PCINT0_vect _VECTOR(2)
301
#define SIG_PIN_CHANGE0 _VECTOR(2)
302
303
/* Timer/Counter0 Overflow */
304
#define TIM0_OVF_vect _VECTOR(3)
305
#define SIG_OVERFLOW0 _VECTOR(3)
306
307
/* EEPROM Ready */
308
#define EE_RDY_vect _VECTOR(4)
309
#define SIG_EEPROM_READY _VECTOR(4)
310
311
/* Analog Comparator */
312
#define ANA_COMP_vect _VECTOR(5)
313
#define SIG_COMPARATOR _VECTOR(5)
314
315
/* Timer/Counter Compare Match A */
316
#define TIM0_COMPA_vect _VECTOR(6)
317
#define SIG_OUTPUT_COMPARE0A _VECTOR(6)
318
319
/* Timer/Counter Compare Match B */
320
#define TIM0_COMPB_vect _VECTOR(7)
321
#define SIG_OUTPUT_COMPARE0B _VECTOR(7)
322
323
/* Watchdog Time-out */
324
#define WDT_vect _VECTOR(8)
325
#define SIG_WATCHDOG_TIMEOUT _VECTOR(8)
326
327
/* ADC Conversion Complete */
328
#define ADC_vect _VECTOR(9)
329
#define SIG_ADC _VECTOR(9)
330
331
#define _VECTORS_SIZE 20
332
333
#define SPM_PAGESIZE 32
334
#define RAMEND 0x9F
335
#define XRAMEND RAMEND
336
#define E2END 0x3F
337
#define E2PAGESIZE 4
338
#define FLASHEND 0x3FF
339
340
341
/* Fuses */
342
343
#define FUSE_MEMORY_SIZE 2
344
345
/* Low Fuse Byte */
346
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
347
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
348
#define FUSE_SUT0 (unsigned char)~_BV(2)
349
#define FUSE_SUT1 (unsigned char)~_BV(3)
350
#define FUSE_CKDIV8 (unsigned char)~_BV(4)
351
#define FUSE_WDTON (unsigned char)~_BV(5)
352
#define FUSE_EESAVE (unsigned char)~_BV(6)
353
#define FUSE_SPIEN (unsigned char)~_BV(7)
354
#define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_SUT0 & FUSE_CKDIV8 & FUSE_SPIEN)
355
356
/* High Fuse Byte */
357
#define FUSE_RSTDISBL (unsigned char)~_BV(0)
358
#define FUSE_BODLEVEL0 (unsigned char)~_BV(1)
359
#define FUSE_BODLEVEL1 (unsigned char)~_BV(2)
360
#define FUSE_DWEN (unsigned char)~_BV(3)
361
#define FUSE_SPMEN (unsigned char)~_BV(4)
362
#define HFUSE_DEFAULT (0xFF)
363
364
365
/* Lock Bits */
366
#define __LOCK_BITS_EXIST
367
368
369
/* Signature */
370
#define SIGNATURE_0 0x1E
371
#define SIGNATURE_1 0x90
372
#define SIGNATURE_2 0x07
373
374
376
#endif
/* _AVR_IOTN13_H_*/
