rtems-4.11.3
score
cpu
avr
avr
iotn11.h
1
9
10
* Copyright (c) 2002, 2005 Marek Michalkiewicz
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOTN11_H_
42
#define _AVR_IOTN11_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "iotn11.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
#ifndef __ASSEMBLER__
62
# warning "MCU not supported by the C compiler"
63
#endif
64
65
/* I/O registers */
66
67
/* 0x00..0x07 reserved */
68
69
/* Analog Comparator Control and Status Register */
70
#define ACSR _SFR_IO8(0x08)
71
72
/* 0x09..0x15 reserved */
73
74
/* Input Pins, Port B */
75
#define PINB _SFR_IO8(0x16)
76
77
/* Data Direction Register, Port B */
78
#define DDRB _SFR_IO8(0x17)
79
80
/* Data Register, Port B */
81
#define PORTB _SFR_IO8(0x18)
82
83
/* 0x19..0x20 reserved */
84
85
/* Watchdog Timer Control Register */
86
#define WDTCR _SFR_IO8(0x21)
87
88
/* 0x22..0x31 reserved */
89
90
/* Timer/Counter0 (8-bit) */
91
#define TCNT0 _SFR_IO8(0x32)
92
93
/* Timer/Counter0 Control Register */
94
#define TCCR0 _SFR_IO8(0x33)
95
96
/* MCU general Status Register */
97
#define MCUSR _SFR_IO8(0x34)
98
99
/* MCU general Control Register */
100
#define MCUCR _SFR_IO8(0x35)
101
102
/* 0x36..0x37 reserved */
103
104
/* Timer/Counter Interrupt Flag Register */
105
#define TIFR _SFR_IO8(0x38)
106
107
/* Timer/Counter Interrupt MaSK Register */
108
#define TIMSK _SFR_IO8(0x39)
109
110
/* General Interrupt Flag Register */
111
#define GIFR _SFR_IO8(0x3A)
112
113
/* General Interrupt MaSK register */
114
#define GIMSK _SFR_IO8(0x3B)
115
116
/* 0x3C..0x3E reserved */
117
118
/* 0x3F SREG */
119
120
/* Interrupt vectors */
121
122
/* External Interrupt 0 */
123
#define INT0_vect _VECTOR(1)
124
#define SIG_INTERRUPT0 _VECTOR(1)
125
126
/* External Interrupt Request 0 */
127
#define IO_PINS_vect _VECTOR(2)
128
#define SIG_PIN _VECTOR(2)
129
#define SIG_PIN_CHANGE _VECTOR(2)
130
131
/* Timer/Counter0 Overflow */
132
#define TIMER0_OVF_vect _VECTOR(3)
133
#define SIG_OVERFLOW0 _VECTOR(3)
134
135
/* Analog Comparator */
136
#define ANA_COMP_vect _VECTOR(4)
137
#define SIG_COMPARATOR _VECTOR(4)
138
139
#define _VECTORS_SIZE 10
140
141
/* Bit numbers */
142
143
/* GIMSK */
144
#define INT0 6
145
#define PCIE 5
146
147
/* GIFR */
148
#define INTF0 6
149
#define PCIF 5
150
151
/* TIMSK */
152
#define TOIE0 1
153
154
/* TIFR */
155
#define TOV0 1
156
157
/* MCUCR */
158
#define SE 5
159
#define SM 4
160
#define ISC01 1
161
#define ISC00 0
162
163
/* TCCR0 */
164
#define CS02 2
165
#define CS01 1
166
#define CS00 0
167
168
/* WDTCR */
169
#define WDTOE 4
170
#define WDE 3
171
#define WDP2 2
172
#define WDP1 1
173
#define WDP0 0
174
175
176
PB5 = RESET#
177
PB4 = XTAL2
178
PB3 = XTAL1
179
PB2 = T0
180
PB1 = INT0 / AIN1
181
PB0 = AIN0
182
183
184
/* PORTB */
185
#define PB4 4
186
#define PB3 3
187
#define PB2 2
188
#define PB1 1
189
#define PB0 0
190
191
/* DDRB */
192
#define DDB4 4
193
#define DDB3 3
194
#define DDB2 2
195
#define DDB1 1
196
#define DDB0 0
197
198
/* PINB */
199
#define PINB5 5
200
#define PINB4 4
201
#define PINB3 3
202
#define PINB2 2
203
#define PINB1 1
204
#define PINB0 0
205
206
/* ACSR */
207
#define ACD 7
208
#define ACO 5
209
#define ACI 4
210
#define ACIE 3
211
#define ACIS1 1
212
#define ACIS0 0
213
214
/* Last memory addresses */
215
#define RAMEND 0x1F
216
#define XRAMEND 0x0
217
#define E2END 0x0
218
#define E2PAGESIZE 2
219
#define FLASHEND 0x3FF
220
221
222
/* Fuses */
223
224
#define FUSE_MEMORY_SIZE 1
225
226
/* Low Fuse Byte */
227
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
228
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
229
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
230
#define FUSE_RSTDISBL (unsigned char)~_BV(3)
231
#define FUSE_FSTRT (unsigned char)~_BV(4)
232
#define FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL1)
233
234
235
/* Lock Bits */
236
#define __LOCK_BITS_EXIST
237
238
239
/* Signature */
240
#define SIGNATURE_0 0x1E
241
#define SIGNATURE_1 0x90
242
#define SIGNATURE_2 0x04
243
244
246
#endif
/* _AVR_IOTN11_H_ */
