rtems-4.11.3
score
cpu
avr
avr
iocan32.h
1
9
10
* Copyright (c) 2004,2005, Anatoly Sokolov <aesok@pautinka.net>
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOCAN32_H_
42
#define _AVR_IOCAN32_H_ 1
43
52
avr/iocanxx.h
53
54
/* Constants */
55
#define SPM_PAGESIZE 256
56
#define RAMEND 0x08FF
/* Last On-Chip SRAM Location */
57
#define XRAMEND 0xFFFF
58
#define E2END 0x03FF
59
#define E2PAGESIZE 8
60
#define FLASHEND 0x7FFF
61
62
63
/* Fuses */
64
65
#define FUSE_MEMORY_SIZE 3
66
67
/* Low Fuse Byte */
68
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
69
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
70
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
71
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
72
#define FUSE_SUT0 (unsigned char)~_BV(4)
73
#define FUSE_SUT1 (unsigned char)~_BV(5)
74
#define FUSE_CKOUT (unsigned char)~_BV(6)
75
#define FUSE_CKDIV8 (unsigned char)~_BV(7)
76
#define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
77
78
/* High Fuse Byte */
79
#define FUSE_BOOTRST (unsigned char)~_BV(0)
80
#define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
81
#define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
82
#define FUSE_EESAVE (unsigned char)~_BV(3)
83
#define FUSE_WDTON (unsigned char)~_BV(4)
84
#define FUSE_SPIEN (unsigned char)~_BV(5)
85
#define FUSE_JTAGEN (unsigned char)~_BV(6)
86
#define FUSE_OCDEN (unsigned char)~_BV(7)
87
#define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
88
89
/* Extended Fuse Byte */
90
#define FUSE_BODLEVEL0 (unsigned char)~_BV(1)
91
#define FUSE_BODLEVEL1 (unsigned char)~_BV(2)
92
#define FUSE_BODLEVEL2 (unsigned char)~_BV(3)
93
#define EFUSE_DEFAULT (0xFF)
94
95
96
/* Lock Bits */
97
#define __LOCK_BITS_EXIST
98
#define __BOOT_LOCK_BITS_0_EXIST
99
#define __BOOT_LOCK_BITS_1_EXIST
100
101
102
/* Signature */
103
#define SIGNATURE_0 0x1E
104
#define SIGNATURE_1 0x95
105
#define SIGNATURE_2 0x81
106
107
109
#endif
/* _AVR_IOCAN32_H_ */
iocanxx.h
Definitions for AT90CAN32, AT90CAN64 and AT90CAN128.
