rtems-4.11.3
score
cpu
avr
avr
io1200.h
1
9
10
* Copyright (c) 2002, Marek Michalkiewicz
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IO1200_H_
42
#define _AVR_IO1200_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "io1200.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
#ifndef __ASSEMBLER__
62
# warning "MCU not supported by the C compiler"
63
#endif
64
65
/* I/O registers */
66
67
/* 0x00..0x07 reserved */
68
69
/* Analog Comparator Control and Status Register */
70
#define ACSR _SFR_IO8(0x08)
71
72
/* 0x09..0x0F reserved */
73
74
#define PIND _SFR_IO8(0x10)
75
#define DDRD _SFR_IO8(0x11)
76
#define PORTD _SFR_IO8(0x12)
77
78
/* 0x13..0x15 reserved */
79
80
#define PINB _SFR_IO8(0x16)
81
#define DDRB _SFR_IO8(0x17)
82
#define PORTB _SFR_IO8(0x18)
83
84
/* 0x19..0x1B reserved */
85
86
/* EEPROM Control Register */
87
#define EECR _SFR_IO8(0x1C)
88
89
/* EEPROM Data Register */
90
#define EEDR _SFR_IO8(0x1D)
91
92
/* EEPROM Address Register */
93
#define EEAR _SFR_IO8(0x1E)
94
#define EEARL _SFR_IO8(0x1E)
95
96
/* 0x1F..0x20 reserved */
97
98
/* Watchdog Timer Control Register */
99
#define WDTCR _SFR_IO8(0x21)
100
101
/* 0x22..0x31 reserved */
102
103
#define TCNT0 _SFR_IO8(0x32)
104
#define TCCR0 _SFR_IO8(0x33)
105
106
/* 0x34 reserved */
107
108
#define MCUCR _SFR_IO8(0x35)
109
110
/* 0x36..0x37 reserved */
111
112
/* Timer/Counter Interrupt Flag Register */
113
#define TIFR _SFR_IO8(0x38)
114
115
/* Timer/Counter Interrupt MaSK Register */
116
#define TIMSK _SFR_IO8(0x39)
117
118
/* 0x3A reserved */
119
120
#define GIMSK _SFR_IO8(0x3B)
121
122
/* 0x3C..0x3E reserved */
123
124
/* 0x3F SREG */
125
126
/* Interrupt vectors */
127
128
/* External Interrupt 0 */
129
#define INT0_vect _VECTOR(1)
130
#define SIG_INTERRUPT0 _VECTOR(1)
131
132
/* Timer/Counter0 Overflow */
133
#define TIMER0_OVF_vect _VECTOR(2)
134
#define SIG_OVERFLOW0 _VECTOR(2)
135
136
/* Analog Comparator */
137
#define ANA_COMP_vect _VECTOR(3)
138
#define SIG_COMPARATOR _VECTOR(3)
139
140
#define _VECTORS_SIZE 8
141
142
/* Bit numbers */
143
144
/* GIMSK */
145
#define INT0 6
146
147
/* TIMSK */
148
#define TOIE0 1
149
150
/* TIFR */
151
#define TOV0 1
152
153
/* MCUCR */
154
#define SE 5
155
#define SM 4
156
#define ISC01 1
157
#define ISC00 0
158
159
/* TCCR0 */
160
#define CS02 2
161
#define CS01 1
162
#define CS00 0
163
164
/* WDTCR */
165
#define WDE 3
166
#define WDP2 2
167
#define WDP1 1
168
#define WDP0 0
169
170
/* EECR */
171
#undef EEMWE
172
173
174
PB7 = SCK
175
PB6 = MISO
176
PB5 = MOSI
177
PB1 = AIN1
178
PB0 = AIN0
179
180
181
/* PORTB */
182
#define PB7 7
183
#define PB6 6
184
#define PB5 5
185
#define PB4 4
186
#define PB3 3
187
#define PB2 2
188
#define PB1 1
189
#define PB0 0
190
191
/* DDRB */
192
#define DDB7 7
193
#define DDB6 6
194
#define DDB5 5
195
#define DDB4 4
196
#define DDB3 3
197
#define DDB2 2
198
#define DDB1 1
199
#define DDB0 0
200
201
/* PINB */
202
#define PINB7 7
203
#define PINB6 6
204
#define PINB5 5
205
#define PINB4 4
206
#define PINB3 3
207
#define PINB2 2
208
#define PINB1 1
209
#define PINB0 0
210
211
/* PORTD */
212
#define PD6 6
213
#define PD5 5
214
#define PD4 4
215
#define PD3 3
216
#define PD2 2
217
#define PD1 1
218
#define PD0 0
219
220
/* DDRD */
221
#define DDD6 6
222
#define DDD5 5
223
#define DDD4 4
224
#define DDD3 3
225
#define DDD2 2
226
#define DDD1 1
227
#define DDD0 0
228
229
/* PIND */
230
#define PIND6 6
231
#define PIND5 5
232
#define PIND4 4
233
#define PIND3 3
234
#define PIND2 2
235
#define PIND1 1
236
#define PIND0 0
237
238
/* ACSR */
239
#define ACD 7
240
#define ACO 5
241
#define ACI 4
242
#define ACIE 3
243
#define ACIS1 1
244
#define ACIS0 0
245
246
247
#define EERIE 3
248
#define EEMWE 2
249
#define EEWE 1
250
#define EERE 0
251
252
#undef ZH
253
254
/* Last memory addresses */
255
#define RAMEND 0x1F
256
#define XRAMEND 0x0
257
#define E2END 0x3F
258
#define E2PAGESIZE 0
259
#define FLASHEND 0x3FF
260
261
262
/* Fuses */
263
#define FUSE_MEMORY_SIZE 1
264
265
/* Low Fuse Byte */
266
#define FUSE_RCEN (unsigned char)~_BV(0)
267
#define FUSE_SPIEN (unsigned char)~_BV(5)
268
#define LFUSE_DEFAULT (0xFF)
269
270
271
/* Lock Bits */
272
#define __LOCK_BITS_EXIST
273
274
275
/* Signature */
276
#define SIGNATURE_0 0x1E
277
#define SIGNATURE_1 0x90
278
#define SIGNATURE_2 0x01
279
280
282
#endif
/* _AVR_IO1200_H_ */
