Message Queue Manager. More...
Modules | |
| Classic Message Queue Implementation | |
Files | |
| file | msg.c |
| Message Queue Manager Initialization. | |
| file | msgdata.c |
| Instantiate the Message Queue Data. | |
| file | msgqbroadcast.c |
| RTEMS Broadcast Message Queue. | |
| file | msgqcreate.c |
| RTEMS Create Message Queue. | |
| file | msgqdelete.c |
| RTEMS Delete Message Queue. | |
| file | msgqflush.c |
| rtems_message_queue_flush | |
| file | msgqgetnumberpending.c |
| RTEMS Message Queue Get Number Pending. | |
| file | msgqident.c |
| RTEMS Message Queue Name to Id. | |
| file | msgqreceive.c |
| RTEMS Message Queue Receive. | |
| file | msgqsend.c |
| rtems_message_queue_send | |
| file | msgqtranslatereturncode.c |
| Message queue Translate Core Message Queue Return Code. | |
| file | msgqurgent.c |
| RTEMS Urgent Message Queue. | |
| rtems_status_code | rtems_message_queue_create (rtems_name name, uint32_t count, size_t max_message_size, rtems_attribute attribute_set, rtems_id *id) |
| RTEMS Create Message Queue. More... | |
| rtems_status_code | rtems_message_queue_ident (rtems_name name, uint32_t node, rtems_id *id) |
| RTEMS Message Queue Name to Id. More... | |
| rtems_status_code | rtems_message_queue_delete (rtems_id id) |
| RTEMS Delete Message Queue. More... | |
| rtems_status_code | rtems_message_queue_send (rtems_id id, const void *buffer, size_t size) |
| rtems_message_queue_send More... | |
| rtems_status_code | rtems_message_queue_urgent (rtems_id id, const void *buffer, size_t size) |
| RTEMS Urgent Message Queue. More... | |
| rtems_status_code | rtems_message_queue_broadcast (rtems_id id, const void *buffer, size_t size, uint32_t *count) |
| RTEMS Broadcast Message Queue. More... | |
| rtems_status_code | rtems_message_queue_receive (rtems_id id, void *buffer, size_t *size, rtems_option option_set, rtems_interval timeout) |
| RTEMS Message Queue Receive. More... | |
| rtems_status_code | rtems_message_queue_flush (rtems_id id, uint32_t *count) |
| rtems_message_queue_flush More... | |
| rtems_status_code | rtems_message_queue_get_number_pending (rtems_id id, uint32_t *count) |
| RTEMS Message Queue Get Number Pending. More... | |
This encapsulates functionality related to the Classic API Message Queue Manager.
This include file contains all the constants and structures associated with the Message Queue Manager. This manager provides a mechanism for communication and synchronization between tasks using messages.
Directives provided are:
| rtems_status_code rtems_message_queue_broadcast | ( | rtems_id | id, |
| const void * | buffer, | ||
| size_t | size, | ||
| uint32_t * | count | ||
This routine implements the rtems_message_queue_broadcast directive. This directive sends the message buffer to all of the tasks blocked waiting for a message on the message queue indicated by ID. If no tasks are waiting, then the message buffer will not be queued.
| [in] | id | is the pointer to message queue |
| [in] | buffer | is the pointer to message buffer |
| [in] | size | is the size of message to broadcast |
| [in] | count | pointer to area to store number of threads made ready |
| RTEMS_SUCCESSFUL | if successful or error code if unsuccessful and *count filled in with number of threads made ready |
| rtems_status_code rtems_message_queue_create | ( | rtems_name | name, |
| uint32_t | count, | ||
| size_t | max_message_size, | ||
| rtems_attribute | attribute_set, | ||
| rtems_id * | id | ||
This routine implements the rtems_message_queue_create directive. The message queue will have the name. If the attribute_set indicates that the message queue is to be limited in the number of messages that can be outstanding, then count indicates the maximum number of messages that will be held. It returns the id of the created message queue in id.
| [in] | name | is the user defined queue name |
| [in] | count | is the maximum message and reserved buffer count |
| [in] | max_message_size | is the maximum size of each message |
| [in] | attribute_set | is the process method |
| [in] | id | is the pointer to queue |
| This | method returns RTEMS_SUCCESSFUL if there was not an error. Otherwise, a status code is returned indicating the source of the error. If successful, the id will be filled in with the queue id. |
References _MPCI_table, MPCI_Control::maximum_packet_size, RTEMS_INVALID_ADDRESS, RTEMS_INVALID_NAME, RTEMS_INVALID_NUMBER, RTEMS_INVALID_SIZE, rtems_is_name_valid(), and RTEMS_MP_NOT_CONFIGURED.
| rtems_status_code rtems_message_queue_delete | ( | rtems_id | id | ) |
This routine implements the rtems_message_queue_delete directive. The message queue indicated by ID is deleted.
| [in] | id | is the queue id |
| RTEMS_SUCCESSFUL | if successful or error code if unsuccessful |
References _Message_queue_Get(), and _Objects_Allocator_lock().
| rtems_status_code rtems_message_queue_flush | ( | rtems_id | id, |
This routine implements the rtems_message_queue_flush directive. This directive takes all outstanding messages for the message queue indicated by ID and returns them to the inactive message chain. The number of messages flushed is returned in COUNT.
References RTEMS_INVALID_ADDRESS.
| rtems_status_code rtems_message_queue_get_number_pending | ( | rtems_id | id, |
This routine implements the rtems_message_queue_get_number_pending directive. This directive returns the number of pending messages for the message queue indicated by ID chain. The number of messages pending is returned in COUNT.
References _Message_queue_Get(), and RTEMS_INVALID_ADDRESS.
| rtems_status_code rtems_message_queue_ident | ( | rtems_name | name, |
| uint32_t | node, | ||
This routine implements the rtems_message_queue_ident directive. This directive returns the message queue ID associated with NAME. If more than one message queue is named name, then the message queue to which the ID belongs is arbitrary. node indicates the extent of the search for the ID of the message queue named name. The search can be limited to a particular node or allowed to encompass all nodes.
| [in] | name | is the user defined message queue name |
| [in] | node | is the node(s) to be searched |
| [in] | id | is the pointer to message queue id |
| RTEMS_SUCCESSFUL | if successful or error code if unsuccessful and *id filled with the message queue id |
| rtems_status_code rtems_message_queue_receive | ( | rtems_id | id, |
| size_t * | size, | ||
| rtems_option | option_set, | ||
| rtems_interval | timeout | ||
This routine implements the rtems_message_queue_receive directive. This directive is invoked when the calling task wishes to receive a message from the message queue indicated by ID. The received message is to be placed in buffer. If no messages are outstanding and the option_set indicates that the task is willing to block, then the task will be blocked until a message arrives or until, optionally, timeout clock ticks have passed.
| [in] | size | is the size of message receive |
| [in] | option_set | is the options on receive |
| [in] | timeout | is the number of ticks to wait |
| This | method returns RTEMS_SUCCESSFUL if there was not an error. Otherwise, a status code is returned indicating the source of the error. |
| rtems_status_code rtems_message_queue_send | ( | rtems_id | id, |
| size_t | size | ||
Message Queue Manager - rtems_message_queue_send
This routine implements the rtems_message_queue_send directive. This directive sends the message buffer to the message queue indicated by ID. If one or more tasks is blocked waiting to receive a message from this message queue, then one will receive the message. The task selected to receive the message is based on the task queue discipline algorithm in use by this particular message queue. If no tasks are waiting, then the message buffer will be placed at the REAR of the chain of pending messages for this message queue.
| rtems_status_code rtems_message_queue_urgent | ( | rtems_id | id, |
| size_t | size | ||
This routine implements the rtems_message_queue_urgent directive. This directive has the same behavior as rtems_message_queue_send except that if no tasks are waiting, the message buffer will be placed at the FRONT of the chain of pending messages rather than at the REAR.
| [in] | size | is the size of message to send urgently |
