rtems-4.11.3
libfs
src
jffs2
include
cyg
infra
cyg_type.h
1
#ifndef CYGONCE_INFRA_CYG_TYPE_H
2
#define CYGONCE_INFRA_CYG_TYPE_H
3
4
5
6
// cyg_type.h
7
8
// Standard types, and some useful coding macros.
9
10
11
// ####ECOSGPLCOPYRIGHTBEGIN####
12
13
// This file is part of eCos, the Embedded Configurable Operating System.
14
// Copyright (C) 1998, 1999, 2000, 2001, 2002, 2009 Free Software Foundation, Inc.
15
16
// eCos is free software; you can redistribute it and/or modify it under
17
// the terms of the GNU General Public License as published by the Free
18
// Software Foundation; either version 2 or (at your option) any later
19
// version.
20
21
// eCos is distributed in the hope that it will be useful, but WITHOUT
22
// ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
23
// FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
24
// for more details.
25
26
// You should have received a copy of the GNU General Public License
27
// along with eCos; if not, write to the Free Software Foundation, Inc.,
28
// 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
29
30
// As a special exception, if other files instantiate templates or use
31
// macros or inline functions from this file, or you compile this file
32
// and link it with other works to produce a work based on this file,
33
// this file does not by itself cause the resulting work to be covered by
34
// the GNU General Public License. However the source code for this file
35
// must still be made available in accordance with section (3) of the GNU
36
// General Public License v2.
37
38
// This exception does not invalidate any other reasons why a work based
39
// on this file might be covered by the GNU General Public License.
40
41
// ####ECOSGPLCOPYRIGHTEND####
42
43
//#####DESCRIPTIONBEGIN####
44
45
// Author(s): nickg from an original by hmt
46
// Contributors: nickg
47
// Date: 1997-09-08
48
// Purpose: share unambiguously sized types.
49
// Description: we typedef [cyg_][u]int8,16,32 &c for general use.
50
// Usage: #include "cyg/infra/cyg_type.h"
51
52
// cyg_int32 my_32bit_integer;
53
54
//####DESCRIPTIONEND####
55
56
57
#include <stddef.h>
// Definition of NULL from the compiler
58
#include <stdint.h>
59
60
typedef
uint16_t cyg_uint16;
61
62
typedef
uint32_t cyg_uint32;
63
64
65
// Allow creation of procedure-like macros that are a single statement,
66
// and must be followed by a semi-colon
67
68
#define CYG_MACRO_START do {
69
#define CYG_MACRO_END } while (0)
70
71
#define CYG_EMPTY_STATEMENT CYG_MACRO_START CYG_MACRO_END
72
73
#define CYG_UNUSED_PARAM( _type_, _name_ ) CYG_MACRO_START \
74
_type_ __tmp1 = (_name_); \
75
_type_ __tmp2 = __tmp1; \
76
__tmp1 = __tmp2; \
77
CYG_MACRO_END
78
79
80
#endif // CYGONCE_INFRA_CYG_TYPE_H multiple inclusion protection
81
// EOF cyg_type.h
