Inlined Routines Associated with the SuperCore Barrier. More...
#include <rtems/score/corebarrier.h>#include <rtems/score/thread.h>#include <rtems/score/threadqimpl.h>#include <rtems/score/watchdog.h>
| #define | CORE_BARRIER_STATUS_LAST CORE_BARRIER_TIMEOUT |
| Core barrier last status value. More... | |
| #define | _CORE_barrier_Flush(_the_barrier, _remote_extract_callout, _status) |
| This routine assists in the deletion of a barrier by flushing the associated wait queue. More... | |
Typedefs | |
| typedef void(* | CORE_barrier_API_mp_support_callout) (Thread_Control *, Objects_Id) |
| The following type defines the callout which the API provides to support global/multiprocessor operations on barriers. | |
Enumerations | |
| enum | CORE_barrier_Status { CORE_BARRIER_STATUS_SUCCESSFUL, CORE_BARRIER_STATUS_AUTOMATICALLY_RELEASED, CORE_BARRIER_WAS_DELETED, CORE_BARRIER_TIMEOUT } |
| Core Barrier handler return statuses. More... | |
| void | _CORE_barrier_Initialize (CORE_barrier_Control *the_barrier, CORE_barrier_Attributes *the_barrier_attributes) |
| Initialize core barrier. More... | |
| RTEMS_INLINE_ROUTINE void | _CORE_barrier_Destroy (CORE_barrier_Control *the_barrier) |
| void | _CORE_barrier_Wait (CORE_barrier_Control *the_barrier, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, CORE_barrier_API_mp_support_callout api_barrier_mp_support) |
| Wait for the barrier. More... | |
| uint32_t | _CORE_barrier_Release (CORE_barrier_Control *the_barrier, Objects_Id id, CORE_barrier_API_mp_support_callout api_barrier_mp_support) |
| Manually release the barrier. More... | |
| RTEMS_INLINE_ROUTINE bool | _CORE_barrier_Is_automatic (CORE_barrier_Attributes *the_attribute) |
| This function returns true if the automatic release attribute is enabled in the attribute_set and false otherwise. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _CORE_barrier_Get_number_of_waiting_threads (CORE_barrier_Control *the_barrier) |
| This routine returns the number of threads currently waiting at the barrier. More... | |
This include file contains all of the inlined routines associated with the SuperCore barrier.
