rtems-4.11.3
posix
include
aio.h
1
10
11
* COPYRIGHT (c) 1989-2011.
12
* On-Line Applications Research Corporation (OAR).
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#ifndef _AIO_H
20
#define _AIO_H
21
22
#include <sys/cdefs.h>
23
#include <unistd.h>
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
39
#if defined(_POSIX_ASYNCHRONOUS_IO)
40
41
42
* 6.7.1 Data Definitions for Asynchronous Input and Output,
43
* P1003.1b-1993, p. 151
44
45
46
#include <sys/types.h>
47
#include <signal.h>
48
time.h
49
#include <fcntl.h>
50
51
52
* 6.7.1.2 Manifest Constants, P1003.1b-1993, p. 153
53
54
55
#define AIO_CANCELED 0
/* all requested operations have been canceled */
56
#define AIO_NOTCANCELED 1
/* some of the operations could not be canceled */
57
/* since they are in progress */
58
#define AIO_ALLDONE 2
/* none of the requested operations could be */
59
/* canceled since they are already complete */
60
61
/* lio_listio() options */
62
63
64
* LIO modes
65
66
#define LIO_WAIT 0
/* calling process is to suspend until the */
67
/* operation is complete */
68
#define LIO_NOWAIT 1
/* calling process is to continue execution while */
69
/* the operation is performed and no notification */
70
/* shall be given when the operation is completed */
71
72
73
* LIO opcodes
74
75
#define LIO_NOP 0
/* no transfer is requested */
76
#define LIO_READ 1
/* request a read() */
77
#define LIO_WRITE 2
/* request a write() */
78
#define LIO_SYNC 3
/* needed by aio_fsync() */
79
80
81
* 6.7.1.1 Asynchronous I/O Control Block, P1003.1b-1993, p. 151
82
83
84
struct
aiocb {
85
/* public */
86
int
aio_fildes;
/* File descriptor */
87
off_t aio_offset;
/* File offset */
88
volatile
void
*aio_buf;
/* Location of buffer */
89
size_t
aio_nbytes;
/* Length of transfer */
90
int
aio_reqprio;
/* Request priority offset */
91
struct
sigevent aio_sigevent;
/* Signal number and value */
92
int
aio_lio_opcode;
/* Operation to be performed */
93
/* private */
94
int
error_code;
/* Used for aio_error() */
95
ssize_t return_value;
/* Used for aio_return() */
96
97
98
99
* 6.7.2 Asynchronous Read, P1003.1b-1993, p. 154
100
101
102
int
aio_read(
103
struct
aiocb *aiocbp
104
105
106
107
* 6.7.3 Asynchronous Write, P1003.1b-1993, p. 155
108
109
110
int
aio_write(
111
struct
aiocb *aiocbp
112
113
114
115
* 6.7.4 List Directed I/O, P1003.1b-1993, p. 158
116
117
118
int
lio_listio(
119
int
mode,
120
struct
aiocb *__restrict
const
list[__restrict],
121
int
nent,
122
struct
sigevent *__restrict sig
123
124
125
126
* 6.7.5 Retrieve Error of Asynchronous I/O Operation, P1003.1b-1993, p. 161
127
128
129
int
aio_error(
130
const
struct
aiocb *aiocbp
131
132
133
134
* 6.7.6 Retrieve Return Status of Asynchronous I/O Operation,
135
* P1003.1b-1993, p. 162
136
137
138
ssize_t aio_return(
139
const
struct
aiocb *aiocbp
140
141
156
int
aio_cancel(
157
int
filedes,
158
struct
aiocb *aiocbp
159
160
161
162
* 6.7.7 Wait for Asynchronous I/O Request, P1003.1b-1993, p. 164
163
164
165
int
aio_suspend(
166
const
struct
aiocb *
const
list[],
167
int
nent,
168
const
struct
timespec *timeout
169
170
171
#if defined(_POSIX_SYNCHRONIZED_IO)
172
173
174
* 6.7.9 Asynchronous File Synchronization, P1003.1b-1993, p. 166
175
176
177
int
aio_fsync(
178
int
op,
179
struct
aiocb *aiocbp
180
181
182
#endif
/* _POSIX_SYNCHRONIZED_IO */
183
184
#endif
/* _POSIX_ASYNCHRONOUS_IO */
185
188
#ifdef __cplusplus
189
190
#endif
191
192
#endif
193
/* end of include file */
time.h
POSIX Time Types.
