Constants and Structures Associated with Watchdog Timers. More...
| struct | Watchdog_Control |
| The control block used to manage each watchdog timer. More... | |
| #define | WATCHDOG_NO_TIMEOUT 0 |
| The constant for indefinite wait. More... | |
Typedefs | |
| typedef uint32_t | Watchdog_Interval |
| Type is used to specify the length of intervals. More... | |
| typedef void | Watchdog_Service_routine |
| Return type from a Watchdog Service Routine. More... | |
| typedef Watchdog_Service_routine(* | Watchdog_Service_routine_entry) (Objects_Id, void *) |
| Pointer to a watchdog service routine. More... | |
Enumerations | |
| enum | Watchdog_States { WATCHDOG_INACTIVE, WATCHDOG_BEING_INSERTED, WATCHDOG_ACTIVE } |
| Set of the states which a watchdog timer may be at any given time. More... | |
| volatile Watchdog_Interval | _Watchdog_Ticks_since_boot |
| The watchdog ticks counter. More... | |
This include file contains all the constants and structures associated with watchdog timers. This Handler provides mechanisms which can be used to initialize and manipulate watchdog timers.
