Files | |
file | address.h [code] |
Information Required to Manipulate Physical Addresses. | |
file | apiext.h [code] |
API Extensions Handler. | |
file | apimutex.h [code] |
API Mutex Handler API. | |
file | assert.h [code] |
file | atomic.h [code] |
Atomic Operations API. | |
file | basedefs.h [code] |
Basic Definitions. | |
file | chain.h [code] |
Chain Handler API. | |
file | chainimpl.h [code] |
file | context.h [code] |
Information About Each Thread's Context. | |
file | copyrt.h [code] |
Copyright Notice for RTEMS. | |
file | corebarrier.h [code] |
Constants and Structures Associated with the Barrier Handler. | |
file | corebarrierimpl.h [code] |
Inlined Routines Associated with the SuperCore Barrier. | |
file | coremsg.h [code] |
Constants and Structures Associated with the Message Queue Handler. | |
file | coremsgimpl.h [code] |
Inlined Routines in the Core Message Handler. | |
file | coremutex.h [code] |
CORE Mutex API. | |
file | coremuteximpl.h [code] |
CORE Mutex Implementation. | |
file | corerwlock.h [code] |
Constants and Structures Associated with the RWLock Handler. | |
file | corerwlockimpl.h [code] |
Inlined Routines Associated with the SuperCore RWLock. | |
file | coresem.h [code] |
Data Associated with the Counting Semaphore Handler. | |
file | coresemimpl.h [code] |
Inlined Routines Associated with the SuperCore Semaphore. | |
file | corespinlock.h [code] |
Constants and Structures Associated with the Spinlock Handler. | |
file | corespinlockimpl.h [code] |
Inlined Routines Associated with the SuperCore Spinlock. | |
file | cpuset.h [code] |
Information About the CPU Set. | |
file | cpusetimpl.h [code] |
Implementation Helper for CPU Set. | |
file | cpustdatomic.h [code] |
Atomic Operations CPU API. | |
file | freechain.h [code] |
Freechain Handler API. | |
file | heap.h [code] |
Heap Handler API. | |
file | heapimpl.h [code] |
Heap Handler Implementation. | |
file | interr.h [code] |
Constants and Prototypes Related to the Internal Error Handler. | |
file | isr.h [code] |
Data Related to the Management of Processor Interrupt Levels. | |
file | isrlevel.h [code] |
ISR Level Type. | |
file | isrlock.h [code] |
ISR Locks. | |
file | mpci.h [code] |
MPCI Layer API. | |
file | mpciimpl.h [code] |
MPCI Layer Implementation. | |
file | mppkt.h [code] |
Specification for the Packet Handler. | |
file | mrsp.h [code] |
file | mrspimpl.h [code] |
file | object.h [code] |
Constants and Structures Associated with the Object Handler. | |
file | objectimpl.h [code] |
Inlined Routines in the Object Handler. | |
file | objectmp.h [code] |
Data Associated with the Manipulation of Global RTEMS Objects. | |
file | onceimpl.h [code] |
Once API. | |
file | percpu.h [code] |
This include file defines the per CPU information required by RTEMS. | |
file | priority.h [code] |
Thread Priority Manipulation Routines. | |
file | prioritybitmap.h [code] |
Manipulation Routines for the Bitmap Priority Queue Implementation. | |
file | prioritybitmapimpl.h [code] |
Inlined Routines in the Priority Handler Bit Map Implementation. | |
file | profiling.h [code] |
Profiling Support API. | |
file | protectedheap.h [code] |
Protected Heap Handler API. | |
file | rbtree.h [code] |
Constants and Structures Associated with the Red-Black Tree Handler. | |
file | rbtreeimpl.h [code] |
Inlined Routines Associated with Red-Black Trees. | |
file | resource.h [code] |
file | resourceimpl.h [code] |
file | scheduler.h [code] |
Constants and Structures Associated with the Scheduler. | |
file | schedulercbs.h [code] |
Thread manipulation for the CBS scheduler. | |
file | schedulercbsimpl.h [code] |
CBS Scheduler Implementation. | |
file | scheduleredf.h [code] |
Data Related to the Manipulation of Threads for the EDF Scheduler. | |
file | scheduleredfimpl.h [code] |
EDF Scheduler Implementation. | |
file | schedulerimpl.h [code] |
Inlined Routines Associated with the Manipulation of the Scheduler. | |
file | schedulerpriority.h [code] |
Thread Manipulation with the Priority-Based Scheduler. | |
file | schedulerpriorityaffinitysmp.h [code] |
Deterministic Priority Affinity SMP Scheduler API. | |
file | schedulerpriorityimpl.h [code] |
Inlined Routines Associated with the Manipulation of the Priority-Based Scheduling Structures. | |
file | schedulerprioritysmp.h [code] |
Deterministic Priority SMP Scheduler API. | |
file | schedulerprioritysmpimpl.h [code] |
file | schedulersimple.h [code] |
Manipulation of Threads Simple-Priority-Based Ready Queue. | |
file | schedulersimpleimpl.h [code] |
file | schedulersimplesmp.h [code] |
Simple SMP Scheduler API. | |
file | schedulersmp.h [code] |
file | schedulersmpimpl.h [code] |
SMP Scheduler Implementation. | |
file | smp.h [code] |
SuperCore SMP Support API. | |
file | smpbarrier.h [code] |
SMP Barrier API. | |
file | smpimpl.h [code] |
SuperCore SMP Implementation. | |
file | smplock.h [code] |
SMP Lock API. | |
file | stack.h [code] |
Information About the Thread Stack Handler. | |
file | stackimpl.h [code] |
Inlined Routines from the Stack Handler. | |
file | states.h [code] |
Thread Execution State Information. | |
file | statesimpl.h [code] |
Inlined Routines Associated with Thread State Information. | |
file | sysstate.h [code] |
System State Handler API. | |
file | thread.h [code] |
Constants and Structures Related with the Thread Control Block. | |
file | threaddispatch.h [code] |
file | threadimpl.h [code] |
Inlined Routines from the Thread Handler. | |
file | threadmp.h [code] |
Multiprocessing Portion of the Thread Package. | |
file | threadq.h [code] |
Constants and Structures Needed to Declare a Thread Queue. | |
file | threadqimpl.h [code] |
Constants and Structures Associated with the Manipulation of Objects. | |
file | timecounter.h [code] |
Timecounter API. | |
file | timecounterimpl.h [code] |
Timecounter Implementation. | |
file | timespec.h [code] |
This include file contains helpers for manipulating timespecs. | |
file | timestamp.h [code] |
Helpers for Manipulating Timestamps. | |
file | tls.h [code] |
Thread-Local Storage (TLS) | |
file | tod.h [code] |
Time of Day Handler API. | |
file | todimpl.h [code] |
file | userext.h [code] |
User Extension Handler API. | |
file | userextimpl.h [code] |
file | watchdog.h [code] |
Constants and Structures Associated with Watchdog Timers. | |
file | watchdogimpl.h [code] |
Inlined Routines in the Watchdog Handler. | |
file | wkspace.h [code] |
Information Related to the RAM Workspace. | |
