#include <rtems/score/object.h>#include <rtems/score/thread.h>#include <rtems/rtems/types.h>#include <rtems/rtems/event.h>#include <rtems/rtems/asr.h>#include <rtems/rtems/attr.h>#include <rtems/rtems/status.h>
| struct | rtems_initialization_tasks_table |
| The following records define the Initialization Tasks Table. More... | |
| struct | RTEMS_API_Control |
| This is the API specific information required by each thread for the RTEMS API to function correctly. More... | |
| #define | RTEMS_SELF OBJECTS_ID_OF_SELF |
| Constant to be used as the ID of current task. | |
| #define | RTEMS_YIELD_PROCESSOR WATCHDOG_NO_TIMEOUT |
| This constant is passed to the rtems_task_wake_after directive as the interval when a task wishes to yield the CPU. | |
| #define | RTEMS_NO_PRIORITY RTEMS_CURRENT_PRIORITY |
| This is the constant used with the rtems_task_set_priority directive to indicate that the caller wants to obtain its current priority rather than set it as the name of the directive indicates. | |
| #define | RTEMS_MINIMUM_PRIORITY (PRIORITY_MINIMUM + 1) |
| This constant is the least valid value for a Classic API task priority. | |
| #define | RTEMS_MAXIMUM_PRIORITY PRIORITY_MAXIMUM |
| This constant is the maximum valid value for a Classic API task priority. More... | |
| #define | RTEMS_CURRENT_PRIORITY PRIORITY_MINIMUM |
| The following constant is passed to rtems_task_set_priority when the caller wants to obtain the current priority. | |
| #define | RTEMS_NOTEPAD_FIRST 0 |
| This is used to indicate the lowest numbered notepad. | |
| #define | RTEMS_NOTEPAD_0 0 |
| This is used to indicate the notepad location 0. More... | |
| #define | RTEMS_NOTEPAD_1 1 |
| This is used to indicate the notepad location 1. More... | |
| #define | RTEMS_NOTEPAD_2 2 |
| This is used to indicate the notepad location 2. More... | |
| #define | RTEMS_NOTEPAD_3 3 |
| This is used to indicate the notepad location 3. More... | |
| #define | RTEMS_NOTEPAD_4 4 |
| This is used to indicate the notepad location 4. More... | |
| #define | RTEMS_NOTEPAD_5 5 |
| This is used to indicate the notepad location 5. More... | |
| #define | RTEMS_NOTEPAD_6 6 |
| This is used to indicate the notepad location 6. More... | |
| #define | RTEMS_NOTEPAD_7 7 |
| This is used to indicate the notepad location 7. More... | |
| #define | RTEMS_NOTEPAD_8 8 |
| This is used to indicate the notepad location 8. More... | |
| #define | RTEMS_NOTEPAD_9 9 |
| This is used to indicate the notepad location 9. More... | |
| #define | RTEMS_NOTEPAD_10 10 |
| This is used to indicate the notepad location 10. More... | |
| #define | RTEMS_NOTEPAD_11 11 |
| This is used to indicate the notepad location 11. More... | |
| #define | RTEMS_NOTEPAD_12 12 |
| This is used to indicate the notepad location 12. More... | |
| #define | RTEMS_NOTEPAD_13 13 |
| This is used to indicate the notepad location 13. More... | |
| #define | RTEMS_NOTEPAD_14 14 |
| This is used to indicate the notepad location 14. More... | |
| #define | RTEMS_NOTEPAD_15 15 |
| This is used to indicate the notepad location 15. More... | |
| #define | RTEMS_NOTEPAD_LAST RTEMS_NOTEPAD_15 |
| This is used to indicate the highest numbered notepad. More... | |
| #define | RTEMS_NUMBER_NOTEPADS (RTEMS_NOTEPAD_LAST+1) |
| This is used to indicate the number of notepads available. More... | |
Typedefs | |
| typedef Priority_Control | rtems_task_priority |
| Define the type for an RTEMS API task priority. | |
| typedef Thread_Control | rtems_tcb |
| External API name for Thread_Control. | |
| typedef void | rtems_task |
| The following defines the "return type" of an RTEMS task. | |
| typedef Thread_Entry_numeric_type | rtems_task_argument |
| The following defines the argument to an RTEMS task. | |
| typedef rtems_task(* | rtems_task_entry) (rtems_task_argument) |
| The following defines the type for the entry point of an RTEMS task. | |
| void(* | _RTEMS_tasks_Initialize_user_tasks_p )(void) |
| When the user configures a set of Classic API initialization tasks, This variable will point to the method used to initialize them. More... | |
| void _RTEMS_tasks_Initialize_user_tasks_body | ( | void | ) |
This routine creates and starts all configured user initialization threads.
Input parameters: NONE
Output parameters: NONE
RTEMS Task Manager
| void(* _RTEMS_tasks_Initialize_user_tasks_p) (void) |
Referenced by _RTEMS_tasks_Initialize_user_tasks().
