Control block used to manage each mutex. More...
#include <coremutex.h>
Data Fields | |
| Thread_queue_Control | Wait_queue |
| This field is the Waiting Queue used to manage the set of tasks which are blocked waiting to lock the mutex. | |
| CORE_mutex_Attributes | Attributes |
| This element is the set of attributes which define this instance's behavior. | |
| uint32_t | nest_count |
| This element contains the number of times the mutex has been acquired nested. More... | |
| Thread_Control * | holder |
| This element points to the thread which is currently holding this mutex. More... | |
The following defines the control block used to manage each mutex.
| Thread_Control* CORE_mutex_Control::holder |
The holder is the last thread to successfully lock the mutex and which has not unlocked it. If the thread is not locked, there is no holder.
Referenced by _API_Mutex_Is_owner(), _CORE_mutex_Initialize(), _CORE_mutex_Is_locked(), _CORE_mutex_Seize_interrupt_trylock_body(), and _CORE_mutex_Surrender().
| uint32_t CORE_mutex_Control::nest_count |
This must be zero (0) before the mutex is actually unlocked.
Referenced by _API_Mutex_Unlock(), _CORE_mutex_Initialize(), and _CORE_mutex_Seize_interrupt_trylock_body().
