Provides routines to ensure mutual exclusion on API level. More...
Modules | |
| RTEMS Allocator Mutex | |
| Protection for all memory allocations and deallocations in RTEMS. | |
Files | |
| file | apimutex.h |
| API Mutex Handler API. | |
| file | apimutex.c |
| Initialization and Allocation for API Mutex Handler. | |
| file | apimutexisowner.c |
| file | apimutexlock.c |
| Acquires the specified API mutex. | |
| file | apimutexunlock.c |
| Releases the Specified API Mutex. | |
| struct | API_Mutex_Control |
| Control block used to manage each API mutex. More... | |
| void | _API_Mutex_Initialization (uint32_t maximum_mutexes) |
| Initialization for the API Mutexe Handler. More... | |
| void | _API_Mutex_Allocate (API_Mutex_Control **mutex) |
| Allocates an API mutex from the inactive set and returns it in mutex. | |
| void | _API_Mutex_Lock (API_Mutex_Control *mutex) |
| Acquires the specified API mutex. More... | |
| void | _API_Mutex_Unlock (API_Mutex_Control *mutex) |
| Releases the specified API mutex. More... | |
| bool | _API_Mutex_Is_owner (const API_Mutex_Control *mutex) |
| Checks if the specified API mutex is owned by the executing thread. More... | |
| void _API_Mutex_Initialization | ( | uint32_t | maximum_mutexes | ) |
The value maximum_mutexes is the maximum number of API mutexes that may exist at any time.
| [in] | maximum_mutexes | is the maximum number of API mutexes. |
References _Objects_Initialize_information().
| bool _API_Mutex_Is_owner | ( | const API_Mutex_Control * | mutex | ) |
| [in] | mutex | The API mutex. |
References _Thread_Get_executing(), CORE_mutex_Control::holder, and API_Mutex_Control::Mutex.
| void _API_Mutex_Lock | ( | API_Mutex_Control * | mutex | ) |
| void _API_Mutex_Unlock | ( | API_Mutex_Control * | mutex | ) |
References _CORE_mutex_Surrender(), _ISR_lock_ISR_disable, Objects_Control::id, API_Mutex_Control::Mutex, CORE_mutex_Control::nest_count, API_Mutex_Control::Object, and API_Mutex_Control::previous_thread_life_protection.
