RTEMS Run-Time Linker Error. More...
#include <errno.h>#include <inttypes.h>#include <stdlib.h>#include <stdio.h>#include <rtems/libio_.h>#include <rtems/rtl/rtl.h>#include "rtl-chain-iterator.h"#include "rtl-obj.h"#include "rtl-error.h"#include "rtl-find-file.h"#include "rtl-string.h"#include "rtl-trace.h"
| struct | rtems_rtl_obj_sect_summer_t |
| Section size summer iterator data. More... | |
| struct | rtems_rtl_obj_sect_aligner_t |
| Section alignment iterator data. More... | |
| struct | rtems_rtl_obj_sect_finder_t |
| Section finder iterator data. More... | |
| struct | rtems_rtl_obj_sect_sync_ctx_t |
| Cache synchronization after runtime object load (dlopen) More... | |
| #define | RTEMS_RTL_RAP_LOADER_COUNT 0 |
| #define | RTEMS_RTL_ELF_LOADER_COUNT 0 |
| #define | RTEMS_RTL_LOADERS (RTEMS_RTL_ELF_LOADER_COUNT + RTEMS_RTL_RAP_LOADER_COUNT) |
| The table of supported loader formats. | |
| #define | RTEMS_RTL_AR_IDENT "!<arch>\n" |
| #define | RTEMS_RTL_AR_IDENT_SIZE (sizeof (RTEMS_RTL_AR_IDENT) - 1) |
| #define | RTEMS_RTL_AR_FHDR_BASE RTEMS_RTL_AR_IDENT_SIZE |
| #define | RTEMS_RTL_AR_FNAME (0) |
| #define | RTEMS_RTL_AR_FNAME_SIZE (16) |
| #define | RTEMS_RTL_AR_SIZE (48) |
| #define | RTEMS_RTL_AR_SIZE_SIZE (10) |
| #define | RTEMS_RTL_AR_MAGIC (58) |
| #define | RTEMS_RTL_AR_MAGIC_SIZE (2) |
| #define | RTEMS_RTL_AR_FHDR_SIZE (60) |
| #define | RTEMS_RTL_MAX_FILE_SIZE (256) |
| rtems_rtl_obj_t * | rtems_rtl_obj_alloc (void) |
| Allocate an object structure on the heap. More... | |
| bool | rtems_rtl_obj_free (rtems_rtl_obj_t *obj) |
| Free the object structure and related resources. More... | |
| bool | rtems_rtl_obj_unresolved (rtems_rtl_obj_t *obj) |
| Does the object file have unresolved external references ? If it does the results of executing code is unpredictable. More... | |
| bool | rtems_rtl_parse_name (const char *name, const char **aname, const char **oname, off_t *ooffset) |
| Parses a filename and returns newly allocated strings with the archive name, object name, and the object's offset. More... | |
| bool | rtems_rtl_match_name (rtems_rtl_obj_t *obj, const char *name) |
| Check of the name matches the object file's object name. More... | |
| bool | rtems_rtl_obj_find_file (rtems_rtl_obj_t *obj, const char *name) |
| Find an object file on disk that matches the name. More... | |
| bool | rtems_rtl_obj_add_section (rtems_rtl_obj_t *obj, int section, const char *name, size_t size, off_t offset, uint32_t alignment, int link, int info, uint32_t flags) |
| Add a section to the object descriptor. More... | |
| void | rtems_rtl_obj_erase_sections (rtems_rtl_obj_t *obj) |
| Erase the object file descriptor's sections. More... | |
| rtems_rtl_obj_sect_t * | rtems_rtl_obj_find_section (const rtems_rtl_obj_t *obj, const char *name) |
| Find the section given a name. More... | |
| rtems_rtl_obj_sect_t * | rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t *obj, int index) |
| Find a section given a section's index number. More... | |
| size_t | rtems_rtl_obj_text_size (const rtems_rtl_obj_t *obj) |
| The text section size. More... | |
| uint32_t | rtems_rtl_obj_text_alignment (const rtems_rtl_obj_t *obj) |
| The text section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_const_size (const rtems_rtl_obj_t *obj) |
| The const section size. More... | |
| uint32_t | rtems_rtl_obj_eh_alignment (const rtems_rtl_obj_t *obj) |
| The eh section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_eh_size (const rtems_rtl_obj_t *obj) |
| The eh section size. More... | |
| uint32_t | rtems_rtl_obj_const_alignment (const rtems_rtl_obj_t *obj) |
| The const section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_data_size (const rtems_rtl_obj_t *obj) |
| The data section size. More... | |
| uint32_t | rtems_rtl_obj_data_alignment (const rtems_rtl_obj_t *obj) |
| The data section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_bss_size (const rtems_rtl_obj_t *obj) |
| The bss section size. More... | |
| uint32_t | rtems_rtl_obj_bss_alignment (const rtems_rtl_obj_t *obj) |
| The bss section alignment for the object file. More... | |
| bool | rtems_rtl_obj_relocate (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_handler_t handler, void *data) |
| Relocate the object file. More... | |
| void | rtems_rtl_obj_synchronize_cache (rtems_rtl_obj_t *obj) |
| Synchronize caches to make code visible to CPU(s) More... | |
| bool | rtems_rtl_obj_load_symbols (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_handler_t handler, void *data) |
| Load the symbols from the object file. More... | |
| bool | rtems_rtl_obj_load_sections (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_handler_t handler, void *data) |
| Load the sections that have been allocated memory in the target. More... | |
| void | rtems_rtl_obj_run_ctors (rtems_rtl_obj_t *obj) |
| Invoke the constructors the object has. More... | |
| void | rtems_rtl_obj_run_dtors (rtems_rtl_obj_t *obj) |
| Invoke the destructors the object has. More... | |
| bool | rtems_rtl_obj_load (rtems_rtl_obj_t *obj) |
| Load the object file, reading all sections into memory, symbols and performing any relocation fixups. More... | |
| bool | rtems_rtl_obj_unload (rtems_rtl_obj_t *obj) |
| Unload the object file, erasing all symbols and releasing all memory. More... | |
| bool rtems_rtl_match_name | ( | rtems_rtl_obj_t * | obj, |
| const char * | name | ||
| obj | The object file's descriptor. |
| name | The name to match. |
References rtems_rtl_obj_s::oname.
| bool rtems_rtl_obj_add_section | ( | rtems_rtl_obj_t * | obj, |
| int | section, | ||
| const char * | name, | ||
| size_t | size, | ||
| off_t | offset, | ||
| uint32_t | alignment, | ||
| int | link, | ||
| int | info, | ||
| uint32_t | flags | ||
| section | The section's index number. |
| name | The name of the section. |
| size | The size of the section in memory. |
| offset | The offset of the section in the object file. |
| alignment | The alignment of the section in memory. |
| link | The section's link field (from the ELF format). |
| info | The section's info field (from the ELF format). |
| flags | The section's flags. |
| true | The section has been added. |
| false | The section has not been added. See the RTL error. |
| rtems_rtl_obj_t* rtems_rtl_obj_alloc | ( | void | ) |
| NULL | No memory for the object. |
References rtems_rtl_obj_s::format, rtems_chain_initialize_empty(), rtems_rtl_alloc_new(), RTEMS_RTL_ALLOC_OBJECT, and rtems_rtl_obj_s::sections.
| uint32_t rtems_rtl_obj_bss_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first bss type section loaded the bss section.
You can assume the alignment is a positive integral power of 2 if not 0 or
Referenced by rtems_rtl_obj_load_sections().
| size_t rtems_rtl_obj_bss_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's bss area.
| uint32_t rtems_rtl_obj_const_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first const type section loaded the const section.
| size_t rtems_rtl_obj_const_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's const area. The consts sections are included in this section.
| uint32_t rtems_rtl_obj_data_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first data type section loaded the data section.
| size_t rtems_rtl_obj_data_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's data area.
| uint32_t rtems_rtl_obj_eh_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
| size_t rtems_rtl_obj_eh_size | ( | const rtems_rtl_obj_t * | obj | ) |
| void rtems_rtl_obj_erase_sections | ( | rtems_rtl_obj_t * | obj | ) |
References rtems_rtl_obj_sect_s::name, rtems_chain_extract(), rtems_chain_first(), rtems_chain_is_tail(), rtems_chain_next(), rtems_rtl_alloc_del(), RTEMS_RTL_ALLOC_OBJECT, and rtems_rtl_obj_s::sections.
| bool rtems_rtl_obj_find_file | ( | rtems_rtl_obj_t * | obj, |
The object descriptor is fill in with the various parts of a name. A name can have archive, object file and offset components. The search path in the RTL is searched.
| name | The name to locate on disk. |
| true | The file has been found. |
| false | The file could not be located. The RTL error has been set. |
| rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section | ( | const rtems_rtl_obj_t * | obj, |
| name | The name of the section to find. |
| NULL | The section was not found. |
References rtems_rtl_obj_sect_finder_t::name, and rtems_rtl_obj_sect_finder_t::sect.
Referenced by rtems_rtl_elf_unwind_dw2_deregister(), and rtems_rtl_elf_unwind_dw2_register().
| rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section_by_index | ( | const rtems_rtl_obj_t * | obj, |
| int | index | ||
| index | The section's index to find. |
Referenced by rtems_rtl_obj_relocate_unresolved().
| bool rtems_rtl_obj_free | ( | rtems_rtl_obj_t * | obj | ) |
| obj | The object file's descriptor to free. |
| false | The object has dependences. |
| true | The object has been freed. |
References rtems_rtl_obj_s::bss_base, rtems_rtl_obj_s::const_base, rtems_rtl_obj_s::data_base, rtems_rtl_obj_s::eh_base, rtems_rtl_obj_s::flags, rtems_rtl_obj_s::link, rtems_chain_extract(), rtems_chain_is_node_off_chain(), rtems_rtl_alloc_module_del(), RTEMS_RTL_OBJ_LOCKED, rtems_rtl_set_error(), rtems_rtl_symbol_obj_erase(), rtems_rtl_obj_s::text_base, and rtems_rtl_obj_s::users.
| bool rtems_rtl_obj_load | ( | rtems_rtl_obj_t * | obj | ) |
| true | The object file has been loaded. |
| false | The load failed. The RTL error has been set. |
| bool rtems_rtl_obj_load_sections | ( | rtems_rtl_obj_t * | obj, |
| int | fd, | ||
| rtems_rtl_obj_sect_handler_t | handler, | ||
| void * | data | ||
The bss type section does not load any data, it is set to 0. The text and data sections read the detault data from the object file into the target memory.
| fd | The object file's file descriptor. |
| handler | The object file's format specific load handler. |
| data | User specific data handle. |
| true | The object has been sucessfully loaded. |
References rtems_rtl_obj_s::bss_base, rtems_rtl_obj_s::bss_size, rtems_rtl_obj_s::const_base, rtems_rtl_obj_s::data_base, rtems_rtl_obj_s::eh_base, rtems_rtl_obj_s::eh_size, rtems_rtl_obj_s::exec_size, rtems_rtl_alloc_module_new(), rtems_rtl_obj_bss_alignment(), rtems_rtl_obj_bss_size(), rtems_rtl_obj_const_alignment(), rtems_rtl_obj_const_size(), rtems_rtl_obj_data_alignment(), rtems_rtl_obj_data_size(), rtems_rtl_obj_eh_alignment(), rtems_rtl_obj_eh_size(), rtems_rtl_obj_text_size(), rtems_rtl_set_error(), rtems_rtl_trace(), rtems_rtl_obj_s::text_base, and rtems_rtl_obj_s::text_size.
| bool rtems_rtl_obj_load_symbols | ( | rtems_rtl_obj_t * | obj, |
| int | fd, | ||
| void * | data | ||
Only the exported or public symbols are read into memory and held in the global symbol table.
| handler | The object file's format specific symbol handler. |
| true | The object file's symbol where loaded. |
| false | The symbol loading failed. The RTL error is set. |
| bool rtems_rtl_obj_relocate | ( | rtems_rtl_obj_t * | obj, |
| int | fd, | ||
| void * | data | ||
The object file's section are parsed for any relocation type sections.
| handler | The object file's format specific relocation handler. |
| true | The object file was relocated. |
| false | The relocation failed. The RTL error is set. |
| void rtems_rtl_obj_run_ctors | ( | rtems_rtl_obj_t * | obj | ) |
Constructors are a table of pointers to "void (*)(void);" where NULL pointers are skipped. The table's size is taken from the section's size. The objet ELF specific code is responisble for flagging which sections contain constructors.
Referenced by rtems_rtl_run_ctors().
| void rtems_rtl_obj_run_dtors | ( | rtems_rtl_obj_t * | obj | ) |
Destructors are a table of pointers to "void (*)(void);" where NULL pointers are skipped. The table's size is taken from the section's size. The objet ELF specific code is responisble for flagging which sections contain destructors.
| void rtems_rtl_obj_synchronize_cache | ( | rtems_rtl_obj_t * | obj | ) |
References rtems_cache_get_instruction_line_size(), rtems_cache_get_maximal_line_size(), rtems_rtl_chain_iterate(), RTEMS_RTL_OBJ_SECT_BSS, RTEMS_RTL_OBJ_SECT_CONST, RTEMS_RTL_OBJ_SECT_DATA, RTEMS_RTL_OBJ_SECT_EH, RTEMS_RTL_OBJ_SECT_EXEC, RTEMS_RTL_OBJ_SECT_TEXT, and rtems_rtl_obj_s::sections.
| uint32_t rtems_rtl_obj_text_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first text type section loaded the text section.
| size_t rtems_rtl_obj_text_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's text area. The consts sections are included in this section.
| bool rtems_rtl_obj_unload | ( | rtems_rtl_obj_t * | obj | ) |
| true | The object file has been unloaded. |
| false | The unload failed. The RTL error has been set. |
| bool rtems_rtl_obj_unresolved | ( | rtems_rtl_obj_t * | obj | ) |
| true | The object file has unresolved externals. |
| false | The object file has all external references resolved. |
References rtems_rtl_obj_s::flags, and RTEMS_RTL_OBJ_UNRESOLVED.
| bool rtems_rtl_parse_name | ( | const char * | name, |
| const char ** | aname, | ||
| const char ** | oname, | ||
| off_t * | ooffset | ||
| name | The filename of the object |
| aname | Address of a string pointer that holds the archive name |
| oname | Address of a string pointer that holds the object name |
| ooffset | Address of an int that holds the object offset |
| true | The parsing was successful |
| false | The parsing was unsuccessful |
Referenced by rtems_rtl_find_obj().
