An object file is made up of sections and the can be more than one of a specific type of sections. More...
#include <rtl-obj.h>
Data Fields | |
| rtems_chain_node | node |
| The node's link in the chain. More... | |
| int | section |
| The section number. More... | |
| const char * | name |
| The section's name. More... | |
| size_t | size |
| The size of the section in memory. More... | |
| off_t | offset |
| Offset into the object file. More... | |
| uint32_t | alignment |
| Alignment of this section. More... | |
| int | link |
| Section link field. More... | |
| int | info |
| Secfion info field. More... | |
| uint32_t | flags |
| The section's flags. More... | |
| void * | base |
| The base address of the section in memory. More... | |
| int | load_order |
| Order we load sections. More... | |
All sections and grouped together in memory.
| uint32_t rtems_rtl_obj_sect_s::alignment |
| void* rtems_rtl_obj_sect_s::base |
Referenced by rtems_rtl_elf_relocate_rel(), rtems_rtl_elf_relocate_rela(), rtems_rtl_elf_unwind_dw2_deregister(), and rtems_rtl_elf_unwind_dw2_register().
| uint32_t rtems_rtl_obj_sect_s::flags |
| int rtems_rtl_obj_sect_s::info |
Secfion info field.
| int rtems_rtl_obj_sect_s::link |
Section link field.
| int rtems_rtl_obj_sect_s::load_order |
| const char* rtems_rtl_obj_sect_s::name |
The section's name.
Referenced by rtems_rtl_obj_erase_sections().
| rtems_chain_node rtems_rtl_obj_sect_s::node |
| off_t rtems_rtl_obj_sect_s::offset |
Relative to the start of the object file.
| int rtems_rtl_obj_sect_s::section |
The section number.
| size_t rtems_rtl_obj_sect_s::size |
Referenced by rtems_rtl_elf_unwind_dw2_deregister(), and rtems_rtl_elf_unwind_dw2_register().
