#include <sys/cdefs.h>#include <errno.h>#include <stdio.h>#include <sys/types.h>#include <sys/stat.h>#include <rtems/rtl/rtl.h>#include "rtl-elf.h"#include "rtl-error.h"#include "rtl-trace.h"#include "rtl-unwind.h"#include "rtl-unwind-dw2.h"
| uint32_t | rtems_rtl_elf_section_flags (const rtems_rtl_obj_t *obj, const Elf_Shdr *shdr) |
| Architecture specific handler to translate unknown section flags to RTL section flags. More... | |
| bool | rtems_rtl_elf_rel_resolve_sym (Elf_Word type) |
| Architecture specific handler to check is a relocation record's type is required to resolve a symbol. More... | |
| bool | rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t *obj, const Elf_Rela *rela, const rtems_rtl_obj_sect_t *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue) |
| Architecture specific relocation handler compiled in for a specific architecture by the build system. More... | |
| bool | rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t *obj, const Elf_Rel *rel, const rtems_rtl_obj_sect_t *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue) |
| bool | rtems_rtl_elf_unwind_parse (const rtems_rtl_obj_t *obj, const char *name, uint32_t flags) |
| Architecture specific handler to check if a section contains exception handler data. More... | |
| bool | rtems_rtl_elf_unwind_register (rtems_rtl_obj_t *obj) |
| Architecture specific handler to add an object file's unwind information to the base image. More... | |
| bool | rtems_rtl_elf_unwind_deregister (rtems_rtl_obj_t *obj) |
| Architecture specific handler to remove an object file's unwind information from the base image. More... | |
| bool rtems_rtl_elf_rel_resolve_sym | ( | Elf_Word | type | ) |
| type | The type field in the relocation record. |
| true | The relocation record require symbol resolution. |
| false | The relocation record does not require symbol resolution. |
References rtems_rtl_elf_relocate_rela().
Referenced by rtems_rtl_elf_section_flags().
| bool rtems_rtl_elf_relocate_rel | ( | const rtems_rtl_obj_t * | obj, |
| const Elf_Rel * | rel, | ||
| const rtems_rtl_obj_sect_t * | sect, | ||
| const char * | symname, | ||
| const Elf_Byte | syminfo, | ||
| const Elf_Word | symvalue | ||
The handler applies the relocation to the target.
| obj | The object file being relocated. |
| rel | The ELF relocation record. |
| sect | The section of the object file the relocation is for. |
| symname | The symbol's name. |
| syminfo | The ELF symbol info field. |
| symvalue | If a symbol is referenced, this is the symbols value. |
| bool | The relocation has been applied. |
| bool | The relocation could not be applied. |
References rtems_rtl_elf_unwind_parse(), and rtems_rtl_set_error().
| bool rtems_rtl_elf_relocate_rela | ( | const rtems_rtl_obj_t * | obj, |
| const Elf_Rela * | rela, | ||
| rela | The ELF addend relocation record. |
References rtems_rtl_obj_sect_s::base.
Referenced by rtems_rtl_elf_rel_resolve_sym().
| uint32_t rtems_rtl_elf_section_flags | ( | const rtems_rtl_obj_t * | obj, |
| const Elf_Shdr * | shdr | ||
| shdr | The ELF section header. |
| 0 | Unknown or unsupported flags. |
| uint32_t | RTL object file flags. |
References rtems_rtl_elf_rel_resolve_sym().
| bool rtems_rtl_elf_unwind_deregister | ( | rtems_rtl_obj_t * | obj | ) |
| obj | The object file. |
| true | The unwind information has been deregistered. |
| false | The unwind information could not be deregistered. |
References rtems_rtl_elf_unwind_dw2_deregister().
Referenced by rtems_rtl_elf_unwind_register().
| bool rtems_rtl_elf_unwind_parse | ( | const rtems_rtl_obj_t * | obj, |
| const char * | name, | ||
| uint32_t | flags | ||
| name | The section's name. |
| uint32 | flags The object file's flags. |
| true | The section contains unwind information. |
| false | The section does not contain unwind information. |
References rtems_rtl_elf_unwind_dw2_parse(), and rtems_rtl_elf_unwind_register().
Referenced by rtems_rtl_elf_relocate_rel().
| bool rtems_rtl_elf_unwind_register | ( | rtems_rtl_obj_t * | obj | ) |
| true | The unwind information has been registered. |
| false | The unwind information could not be registered. |
References rtems_rtl_elf_unwind_deregister(), and rtems_rtl_elf_unwind_dw2_register().
Referenced by rtems_rtl_elf_unwind_parse().
