timer.h
1
30 /*
31  * COPYRIGHT (c) 1989-2011.
32  * On-Line Applications Research Corporation (OAR).
33  *
34  * Copyright (c) 2009 embedded brains GmbH.
35  *
36  * The license and distribution terms for this file may be
37  * found in the file LICENSE in this distribution or at
38  * http://www.rtems.org/license/LICENSE.
39  */
40
41 #ifndef _RTEMS_RTEMS_TIMER_H
42 #define _RTEMS_RTEMS_TIMER_H
43
44 #include <rtems/rtems/attr.h>
45 #include <rtems/rtems/status.h>
46 #include <rtems/rtems/types.h>
47
48 #ifdef __cplusplus
49 extern "C" {
50 #endif
51
70 typedef enum {
76
82
88
94
100
105
112  rtems_id,
113  void *
114  );
115
120 typedef struct {
126  Timer_Classes the_class;
127 } Timer_Control;
128
142  rtems_name name,
143  rtems_id *id
144 );
145
161  rtems_name name,
162  rtems_id *id
163 );
164
172  rtems_id id
173 );
174
188  rtems_id id
189 );
190
210  rtems_id id,
211  rtems_interval ticks,
213  void *user_data
214 );
215
235  rtems_id id,
236  rtems_interval ticks,
238  void *user_data
239 );
240
260  rtems_id id,
261  rtems_time_of_day *wall_time,
263  void *user_data
264 );
265
278  rtems_id id,
279  rtems_time_of_day *wall_time,
281  void *user_data
282 );
283
295  rtems_id id
296 );
297
306  uint32_t priority,
307  uint32_t stack_size,
308  rtems_attribute attribute_set
309 );
310
316 #define RTEMS_TIMER_SERVER_DEFAULT_PRIORITY (uint32_t) -1
317
322 typedef struct {
324  Timer_Classes the_class;
332
346  rtems_id id,
347  rtems_timer_information *the_info
348 );
349
352 #ifdef __cplusplus
353 }
354 #endif
355
356 #endif
357 /* end of include file */
This value indicates the timer is currently in use as an time of day timer which will fire in the tim...
Definition: timer.h:93
This indicates the current type of the timer.
Definition: timer.h:324
uint32_t rtems_attribute
This defines the type used to contain Classic API attributes.
Definition: attr.h:44
rtems_status_code rtems_timer_cancel(rtems_id id)
rtems_timer_cancel
Definition: timercancel.c:38
The following defines the Object Control Block used to manage each object local to this node...
Definition: object.h:232
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:80
This value indicates the timer is currently in use as an interval timer which will fire in the clock ...
Definition: timer.h:75
rtems_status_code rtems_timer_fire_after(rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Fire After.
Definition: timerfireafter.c:28
Watchdog_Interval start_time
This indicates the time the timer was initially scheduled.
Definition: timer.h:328
The control block used to manage each watchdog timer.
Definition: watchdog.h:98
This value indicates the timer is currently not in use.
Definition: timer.h:98
rtems_status_code rtems_timer_delete(rtems_id id)
RTEMS Delete Timer.
Definition: timerdelete.c:28
Objects_Control Object
This field is the object management portion of a Timer instance.
Definition: timer.h:122
rtems_status_code rtems_timer_server_fire_when(rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Server Fire When Directive.
Definition: timerserverfirewhen.c:43
This value indicates the timer is currently in use as an interval timer which will fire in the timer ...
Definition: timer.h:81
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:119
rtems_status_code rtems_timer_create(rtems_name name, rtems_id *id)
RTEMS Create Timer.
Definition: timercreate.c:57
Data structure to manage and manipulate calendar time.
Definition: types.h:133
rtems_status_code
Classic API Status.
Definition: status.h:46
rtems_status_code rtems_timer_ident(rtems_name name, rtems_id *id)
RTEMS Timer Name to Id.
Definition: timerident.c:28
This is the structure filled in by the timer get information service.
Definition: timer.h:322
rtems_status_code rtems_timer_reset(rtems_id id)
RTEMS Timer Reset.
Definition: timerreset.c:41
rtems_status_code rtems_timer_fire_when(rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Fire When.
Definition: timerfirewhen.c:26
uint32_t rtems_name
Classic API object name type.
Definition: types.h:74
Watchdog_Control Ticker
This field is the Watchdog instance which will be the scheduled.
Definition: timer.h:124
rtems_status_code rtems_timer_get_information(rtems_id id, rtems_timer_information *the_info)
RTEMS Get Timer Information.
Definition: timergetinfo.c:28
rtems_status_code rtems_timer_initiate_server(uint32_t priority, uint32_t stack_size, rtems_attribute attribute_set)
Definition: timerserver.c:323
rtems_status_code rtems_timer_server_fire_after(rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Server Fire After.
Definition: timerserverfireafter.c:28
Timer_Classes
The following enumerated type details the classes to which a timer may belong.
Definition: timer.h:70
Watchdog_Interval initial
This indicates the initial requested interval.
Definition: timer.h:326
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdog.h:47
This value indicates the timer is currently in use as an time of day timer which will fire in the clo...
Definition: timer.h:87
Watchdog_Interval stop_time
This indicates the time the timer is scheduled to fire.
Definition: timer.h:330
This field indicates what type of timer this currently is.
Definition: timer.h:126
The following records define the control block used to manage each timer.
Definition: timer.h:120
rtems_timer_service_routine(* rtems_timer_service_routine_entry)(rtems_id, void *)
This type defines the type used to manage and indirectly invoke Timer Service Routines (TSRs)...
Definition: timer.h:111
void rtems_timer_service_routine
The following types define a pointer to a timer service routine.
Definition: timer.h:104
