| #define | RTEMS_STATUS_CODES_FIRST RTEMS_SUCCESSFUL |
| This is the lowest valid value for a Classic API status code. | |
| #define | RTEMS_STATUS_CODES_LAST RTEMS_PROXY_BLOCKING |
| This is the highest valid value for a Classic API status code. | |
Enumerations | |
| enum | rtems_status_code { RTEMS_SUCCESSFUL = 0, RTEMS_TASK_EXITTED = 1, RTEMS_MP_NOT_CONFIGURED = 2, RTEMS_INVALID_NAME = 3, RTEMS_INVALID_ID = 4, RTEMS_TOO_MANY = 5, RTEMS_TIMEOUT = 6, RTEMS_OBJECT_WAS_DELETED = 7, RTEMS_INVALID_SIZE = 8, RTEMS_INVALID_ADDRESS = 9, RTEMS_INVALID_NUMBER = 10, RTEMS_NOT_DEFINED = 11, RTEMS_RESOURCE_IN_USE = 12, RTEMS_UNSATISFIED = 13, RTEMS_INCORRECT_STATE = 14, RTEMS_ALREADY_SUSPENDED = 15, RTEMS_ILLEGAL_ON_SELF = 16, RTEMS_ILLEGAL_ON_REMOTE_OBJECT = 17, RTEMS_CALLED_FROM_ISR = 18, RTEMS_INVALID_PRIORITY = 19, RTEMS_INVALID_CLOCK = 20, RTEMS_INVALID_NODE = 21, RTEMS_NOT_CONFIGURED = 22, RTEMS_NOT_OWNER_OF_RESOURCE = 23, RTEMS_NOT_IMPLEMENTED = 24, RTEMS_INTERNAL_ERROR = 25, RTEMS_NO_MEMORY = 26, RTEMS_IO_ERROR = 27, RTEMS_PROXY_BLOCKING = 28 } |
| Classic API Status. More... | |
| RTEMS_INLINE_ROUTINE bool | rtems_is_status_successful (rtems_status_code code) |
| Checks if the status code is equal to RTEMS_SUCCESSFUL. More... | |
| RTEMS_INLINE_ROUTINE bool | rtems_are_statuses_equal (rtems_status_code code1, rtems_status_code code2) |
| Checks if the status code1 is equal to code2. More... | |
| int | rtems_status_code_to_errno (rtems_status_code sc) |
| RTEMS Status Code to Errno Mapping Function. More... | |
| const char * | rtems_status_text (rtems_status_code code) |
| Returns a text for a status code. More... | |
