Definitions for ATtiny15. More...
#define | _AVR_IOXXX_H_ "iotn15.h" |
#define | ADC _SFR_IO16 (0x04) |
#define | ADCW _SFR_IO16(0x04) |
#define | ADCL _SFR_IO8(0x04) |
#define | ADCH _SFR_IO8(0x05) |
#define | ADCSR _SFR_IO8(0x06) |
#define | ADMUX _SFR_IO8(0x07) |
#define | ACSR _SFR_IO8(0x08) |
#define | PINB _SFR_IO8(0x16) |
#define | DDRB _SFR_IO8(0x17) |
#define | PORTB _SFR_IO8(0x18) |
#define | EECR _SFR_IO8(0x1C) |
#define | EEDR _SFR_IO8(0x1D) |
#define | EEAR _SFR_IO8(0x1E) |
#define | EEARL _SFR_IO8(0x1E) |
#define | WDTCR _SFR_IO8(0x21) |
#define | SFIOR _SFR_IO8(0x2C) |
#define | OCR1B _SFR_IO8(0x2D) |
#define | OCR1A _SFR_IO8(0x2E) |
#define | TCNT1 _SFR_IO8(0x2F) |
#define | TCCR1 _SFR_IO8(0x30) |
#define | OSCCAL _SFR_IO8(0x31) |
#define | TCNT0 _SFR_IO8(0x32) |
#define | TCCR0 _SFR_IO8(0x33) |
#define | MCUSR _SFR_IO8(0x34) |
#define | MCUCR _SFR_IO8(0x35) |
#define | TIFR _SFR_IO8(0x38) |
#define | TIMSK _SFR_IO8(0x39) |
#define | GIFR _SFR_IO8(0x3A) |
#define | GIMSK _SFR_IO8(0x3B) |
#define | INT0_vect _VECTOR(1) |
#define | SIG_INTERRUPT0 _VECTOR(1) |
#define | IO_PINS_vect _VECTOR(2) |
#define | SIG_PIN _VECTOR(2) |
#define | SIG_PIN_CHANGE _VECTOR(2) |
#define | TIMER1_COMP_vect _VECTOR(3) |
#define | SIG_OUTPUT_COMPARE1A _VECTOR(3) |
#define | TIMER1_OVF_vect _VECTOR(4) |
#define | SIG_OVERFLOW1 _VECTOR(4) |
#define | TIMER0_OVF_vect _VECTOR(5) |
#define | SIG_OVERFLOW0 _VECTOR(5) |
#define | EE_RDY_vect _VECTOR(6) |
#define | SIG_EEPROM_READY _VECTOR(6) |
#define | ANA_COMP_vect _VECTOR(7) |
#define | SIG_COMPARATOR _VECTOR(7) |
#define | ADC_vect _VECTOR(8) |
#define | SIG_ADC _VECTOR(8) |
#define | _VECTORS_SIZE 18 |
#define | INT0 6 |
#define | PCIE 5 |
#define | INTF0 6 |
#define | PCIF 5 |
#define | OCIE1 6 |
#define | TOIE1 2 |
#define | TOIE0 1 |
#define | OCF1 6 |
#define | TOV1 2 |
#define | TOV0 1 |
#define | PUD 6 |
#define | SE 5 |
#define | SM1 4 |
#define | SM0 3 |
#define | ISC01 1 |
#define | ISC00 0 |
#define | WDRF 3 |
#define | BORF 2 |
#define | EXTRF 1 |
#define | PORF 0 |
#define | CS02 2 |
#define | CS01 1 |
#define | CS00 0 |
#define | CTC1 7 |
#define | PWM1 6 |
#define | COM1A1 5 |
#define | COM1A0 4 |
#define | CS13 3 |
#define | CS12 2 |
#define | CS11 1 |
#define | CS10 0 |
#define | FOC1A 2 |
#define | PSR1 1 |
#define | PSR0 0 |
#define | WDTOE 4 |
#define | WDE 3 |
#define | WDP2 2 |
#define | WDP1 1 |
#define | WDP0 0 |
#define | PB4 4 |
#define | PB3 3 |
#define | PB2 2 |
#define | PB1 1 |
#define | PB0 0 |
#define | DDB4 4 |
#define | DDB3 3 |
#define | DDB2 2 |
#define | DDB1 1 |
#define | DDB0 0 |
#define | PINB5 5 |
#define | PINB4 4 |
#define | PINB3 3 |
#define | PINB2 2 |
#define | PINB1 1 |
#define | PINB0 0 |
#define | ACD 7 |
#define | GREF 6 |
#define | ACO 5 |
#define | ACI 4 |
#define | ACIE 3 |
#define | ACIS1 1 |
#define | ACIS0 0 |
#define | REFS1 7 |
#define | REFS0 6 |
#define | ADLAR 5 |
#define | MUX2 2 |
#define | MUX1 1 |
#define | MUX0 0 |
#define | ADEN 7 |
#define | ADSC 6 |
#define | ADFR 5 |
#define | ADIF 4 |
#define | ADIE 3 |
#define | ADPS2 2 |
#define | ADPS1 1 |
#define | ADPS0 0 |
#define | EERIE 3 |
#define | EEMWE 2 |
#define | EEWE 1 |
#define | EERE 0 |
#define | RAMEND 0x1F |
#define | XRAMEND 0x0 |
#define | E2END 0x3F |
#define | E2PAGESIZE 2 |
#define | FLASHEND 0x3FF |
#define | FUSE_MEMORY_SIZE 1 |
#define | FUSE_CKSEL0 (unsigned char)~_BV(0) |
#define | FUSE_CKSEL1 (unsigned char)~_BV(1) |
#define | FUSE_RSTDISBL (unsigned char)~_BV(4) |
#define | FUSE_SPIEN (unsigned char)~_BV(5) |
#define | FUSE_BODEN (unsigned char)~_BV(6) |
#define | FUSE_BODLEVEL (unsigned char)~_BV(7) |
#define | FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL1 & FUSE_SPIEN) |
#define | __LOCK_BITS_EXIST |
#define | SIGNATURE_0 0x1E |
#define | SIGNATURE_1 0x90 |
#define | SIGNATURE_2 0x06 |
This file should only be included from <avr/io.h>, never directly.
