AVR device-specific IO Definitions. More...
#include <avr/sfr_defs.h>
#include <avr/portpins.h>
#include <avr/common.h>
#include <avr/version.h>
#include <avr/fuse.h>
#include <avr/lock.h>
This header file includes the apropriate IO definitions for the device that has been specified by the -mmcu=
compiler command-line switch. This is done by diverting to the appropriate file <avr/io
XXXX.h>
which should never be included directly. Some register names common to all AVR devices are defined directly within <avr/common.h>
, which is included in <avr/io.h>
, but most of the details come from the respective include file.
Note that this file always includes the following files:
See avr_sfr for more details about that header file.
Included are definitions of the IO register set and their respective bit values as specified in the Atmel documentation. Note that inconsistencies in naming conventions, so even identical functions sometimes get different names on different devices.
Also included are the specific names useable for interrupt function definitions as documented here.
Finally, the following macros are defined:
SPM
instruction.
