score
cpu
avr
avr
iotn15.h
1
9
10
* Copyright (c) 2002,2005 Marek Michalkiewicz
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOTN15_H_
42
#define _AVR_IOTN15_H_ 1
43
52
#ifndef _AVR_IO_H_
53
# error "Include <avr/io.h> instead of this file."
54
#endif
55
56
#ifndef _AVR_IOXXX_H_
57
# define _AVR_IOXXX_H_ "iotn15.h"
58
#else
59
# error "Attempt to include more than one <avr/ioXXX.h> file."
60
#endif
61
62
#ifndef __ASSEMBLER__
63
# warning "MCU not supported by the C compiler"
64
#endif
65
66
/* I/O registers */
67
68
/* 0x00..0x03 reserved */
69
70
71
#define ADC _SFR_IO16 (0x04)
72
#endif
73
#define ADCW _SFR_IO16(0x04)
74
#define ADCL _SFR_IO8(0x04)
75
#define ADCH _SFR_IO8(0x05)
76
#define ADCSR _SFR_IO8(0x06)
77
#define ADMUX _SFR_IO8(0x07)
78
79
/* Analog Comparator Control and Status Register */
80
#define ACSR _SFR_IO8(0x08)
81
82
/* 0x09..0x15 reserved */
83
84
/* Input Pins, Port B */
85
#define PINB _SFR_IO8(0x16)
86
87
/* Data Direction Register, Port B */
88
#define DDRB _SFR_IO8(0x17)
89
90
/* Data Register, Port B */
91
#define PORTB _SFR_IO8(0x18)
92
93
/* 0x19..0x1B reserved */
94
95
/* EEPROM Control Register */
96
#define EECR _SFR_IO8(0x1C)
97
98
/* EEPROM Data Register */
99
#define EEDR _SFR_IO8(0x1D)
100
101
/* EEPROM Address Register */
102
#define EEAR _SFR_IO8(0x1E)
103
#define EEARL _SFR_IO8(0x1E)
104
105
/* 0x1F..0x20 reserved */
106
107
/* Watchdog Timer Control Register */
108
#define WDTCR _SFR_IO8(0x21)
109
110
/* 0x22..0x2B reserved */
111
#define SFIOR _SFR_IO8(0x2C)
112
113
#define OCR1B _SFR_IO8(0x2D)
114
#define OCR1A _SFR_IO8(0x2E)
115
#define TCNT1 _SFR_IO8(0x2F)
116
#define TCCR1 _SFR_IO8(0x30)
117
118
/* Oscillator Calibration Register */
119
#define OSCCAL _SFR_IO8(0x31)
120
121
/* Timer/Counter0 (8-bit) */
122
#define TCNT0 _SFR_IO8(0x32)
123
124
/* Timer/Counter0 Control Register */
125
#define TCCR0 _SFR_IO8(0x33)
126
127
/* MCU general Status Register */
128
#define MCUSR _SFR_IO8(0x34)
129
130
/* MCU general Control Register */
131
#define MCUCR _SFR_IO8(0x35)
132
133
/* 0x36..0x37 reserved */
134
135
/* Timer/Counter Interrupt Flag Register */
136
#define TIFR _SFR_IO8(0x38)
137
138
/* Timer/Counter Interrupt MaSK Register */
139
#define TIMSK _SFR_IO8(0x39)
140
141
/* General Interrupt Flag Register */
142
#define GIFR _SFR_IO8(0x3A)
143
144
/* General Interrupt MaSK register */
145
#define GIMSK _SFR_IO8(0x3B)
146
147
/* 0x3C..0x3E reserved */
148
149
/* 0x3F SREG */
150
151
/* Interrupt vectors */
152
153
/* External Interrupt 0 */
154
#define INT0_vect _VECTOR(1)
155
#define SIG_INTERRUPT0 _VECTOR(1)
156
157
/* External Interrupt Request 0 */
158
#define IO_PINS_vect _VECTOR(2)
159
#define SIG_PIN _VECTOR(2)
160
#define SIG_PIN_CHANGE _VECTOR(2)
161
162
/* Timer/Counter1 Compare Match */
163
#define TIMER1_COMP_vect _VECTOR(3)
164
#define SIG_OUTPUT_COMPARE1A _VECTOR(3)
165
166
/* Timer/Counter1 Overflow */
167
#define TIMER1_OVF_vect _VECTOR(4)
168
#define SIG_OVERFLOW1 _VECTOR(4)
169
170
/* Timer/Counter0 Overflow */
171
#define TIMER0_OVF_vect _VECTOR(5)
172
#define SIG_OVERFLOW0 _VECTOR(5)
173
174
/* EEPROM Ready */
175
#define EE_RDY_vect _VECTOR(6)
176
#define SIG_EEPROM_READY _VECTOR(6)
177
178
/* Analog Comparator */
179
#define ANA_COMP_vect _VECTOR(7)
180
#define SIG_COMPARATOR _VECTOR(7)
181
182
/* ADC Conversion Ready */
183
#define ADC_vect _VECTOR(8)
184
#define SIG_ADC _VECTOR(8)
185
186
#define _VECTORS_SIZE 18
187
188
/* Bit numbers */
189
190
/* GIMSK */
191
#define INT0 6
192
#define PCIE 5
193
194
/* GIFR */
195
#define INTF0 6
196
#define PCIF 5
197
198
/* TIMSK */
199
#define OCIE1 6
200
#define TOIE1 2
201
#define TOIE0 1
202
203
/* TIFR */
204
#define OCF1 6
205
#define TOV1 2
206
#define TOV0 1
207
208
/* MCUCR */
209
#define PUD 6
210
#define SE 5
211
#define SM1 4
212
#define SM0 3
213
#define ISC01 1
214
#define ISC00 0
215
216
/* MCUSR */
217
#define WDRF 3
218
#define BORF 2
219
#define EXTRF 1
220
#define PORF 0
221
222
/* TCCR0 */
223
#define CS02 2
224
#define CS01 1
225
#define CS00 0
226
227
/* TCCR1 */
228
#define CTC1 7
229
#define PWM1 6
230
#define COM1A1 5
231
#define COM1A0 4
232
#define CS13 3
233
#define CS12 2
234
#define CS11 1
235
#define CS10 0
236
237
/* SFIOR */
238
#define FOC1A 2
239
#define PSR1 1
240
#define PSR0 0
241
242
/* WDTCR */
243
#define WDTOE 4
244
#define WDE 3
245
#define WDP2 2
246
#define WDP1 1
247
#define WDP0 0
248
249
250
PB5 = RESET# / ADC0
251
PB4 = ADC3
252
PB3 = ADC2
253
PB2 = SCK / ADC1 / T0 / INT0
254
PB1 = MISO / AIN1 / OCP
255
PB0 = MOSI / AIN0 / AREF
256
257
258
/* PORTB */
259
#define PB4 4
260
#define PB3 3
261
#define PB2 2
262
#define PB1 1
263
#define PB0 0
264
265
/* DDRB */
266
#define DDB4 4
267
#define DDB3 3
268
#define DDB2 2
269
#define DDB1 1
270
#define DDB0 0
271
272
/* PINB */
273
#define PINB5 5
274
#define PINB4 4
275
#define PINB3 3
276
#define PINB2 2
277
#define PINB1 1
278
#define PINB0 0
279
280
/* ACSR */
281
#define ACD 7
282
#define GREF 6
283
#define ACO 5
284
#define ACI 4
285
#define ACIE 3
286
#define ACIS1 1
287
#define ACIS0 0
288
289
/* ADMUX */
290
#define REFS1 7
291
#define REFS0 6
292
#define ADLAR 5
293
#define MUX2 2
294
#define MUX1 1
295
#define MUX0 0
296
297
/* ADCSR */
298
#define ADEN 7
299
#define ADSC 6
300
#define ADFR 5
301
#define ADIF 4
302
#define ADIE 3
303
#define ADPS2 2
304
#define ADPS1 1
305
#define ADPS0 0
306
307
308
#define EERIE 3
309
#define EEMWE 2
310
#define EEWE 1
311
#define EERE 0
312
313
/* Last memory addresses */
314
#define RAMEND 0x1F
315
#define XRAMEND 0x0
316
#define E2END 0x3F
317
#define E2PAGESIZE 2
318
#define FLASHEND 0x3FF
319
320
321
/* Fuses */
322
323
#define FUSE_MEMORY_SIZE 1
324
325
/* Fuse Byte */
326
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
327
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
328
#define FUSE_RSTDISBL (unsigned char)~_BV(4)
329
#define FUSE_SPIEN (unsigned char)~_BV(5)
330
#define FUSE_BODEN (unsigned char)~_BV(6)
331
#define FUSE_BODLEVEL (unsigned char)~_BV(7)
332
#define FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL1 & FUSE_SPIEN)
333
334
335
/* Lock Bits */
336
#define __LOCK_BITS_EXIST
337
338
339
/* Signature */
340
#define SIGNATURE_0 0x1E
341
#define SIGNATURE_1 0x90
342
#define SIGNATURE_2 0x06
343
345
#endif
/* _AVR_IOTN15_H_ */
