CPU Usage Report. More...
Files | |
| file | cpuusagedata.c |
| CPU Usage DataCPU Usage Reporter - Shared Data. | |
| file | cpuusagereport.c |
| CPU Usage Report. | |
| file | cpuusagereset.c |
| CPU Usage Reset. | |
| file | cpuusagetop.c |
| CPU Usage Top. | |
| void | rtems_cpu_usage_report_with_plugin (void *context, rtems_printk_plugin_t handler) |
| void | rtems_cpu_usage_report (void) |
| Report CPU usage. More... | |
| void | rtems_cpu_usage_top_with_plugin (void *context, rtems_printk_plugin_t print) |
| CPU usage Top plugin. More... | |
| void | rtems_cpu_usage_top (void) |
| CPU usage top. More... | |
| void | rtems_cpu_usage_reset (void) |
| Reset CPU usage. More... | |
| Timestamp_Control | CPU_usage_Uptime_at_last_reset |
CPU Usage Report.
This include file contains information necessary to utilize and install the cpu usage reporting mechanism.
| void rtems_cpu_usage_report | ( | void | ) |
Report CPU usage.
CPU Usage Reporter
| void rtems_cpu_usage_reset | ( | void | ) |
Reset CPU usage.
CPU Usage Reporter
| void rtems_cpu_usage_top | ( | void | ) |
| void rtems_cpu_usage_top_with_plugin | ( | void * | context, |
| rtems_printk_plugin_t | |||
Report CPU Usage in top format to to a print plugin.
Referenced by rtems_cpu_usage_top().
