cpuusagetop.c File Reference
CPU Usage Top. More...
#include <stdbool.h>
#include <ctype.h>
#include <inttypes.h>
#include <rtems/cpuuse.h>
#include <rtems/malloc.h>
#include <rtems/score/protectedheap.h>
Include dependency graph for cpuusagetop.c:
struct  rtems_cpu_usage_plugin
struct  rtems_cpu_usage_data
#define RTEMS_TOP_SORT_ID   (0)
#define RTEMS_TOP_SORT_REAL_PRI   (1)
#define RTEMS_TOP_SORT_CURRENT_PRI   (2)
#define RTEMS_TOP_SORT_TOTAL   (3)
#define RTEMS_TOP_SORT_CURRENT   (4)
#define RTEMS_TOP_SORT_MAX   (4)
#define CPU_usage_Equal_to(_lhs, _rhs)   _Timestamp_Equal_to( _lhs, _rhs )
#define CPU_usage_Set_to_zero(_time)   _Timestamp_Set_to_zero( _time )
#define CPU_usage_Less_than(_lhs, _rhs)   _Timestamp_Less_than( _lhs, _rhs )
typedef void(* rtems_per_thread_routine_2) (Thread_Control *, void *)
void rtems_iterate_over_all_threads_2 (rtems_per_thread_routine_2 routine, void *arg)
void rtems_cpu_usage_top_with_plugin (void *context, rtems_printk_plugin_t print)
 CPU usage Top plugin. More...
void rtems_cpu_usage_top (void)
 CPU usage top. More...
CPU Usage Top.
