Mount options for the Journalling Flash File System, Version 2 (JFFS2).
More...
| typedef int(* | rtems_jffs2_flash_read) (rtems_jffs2_flash_control *self, uint32_t offset, unsigned char *buffer, size_t size_of_buffer) |
| | Read from flash operation. More...
| typedef int(* | rtems_jffs2_flash_write) (rtems_jffs2_flash_control *self, uint32_t offset, const unsigned char *buffer, size_t size_of_buffer) |
| | Write to flash operation. More...
| typedef int(* | rtems_jffs2_flash_erase) (rtems_jffs2_flash_control *self, uint32_t offset) |
| | Flash erase operation. More...
| typedef void(* | rtems_jffs2_flash_destroy) (rtems_jffs2_flash_control *self) |
| | Flash destroy operation. More...
typedef struct rtems_jffs2_compressor_control | rtems_jffs2_compressor_control |
| typedef uint16_t(* | rtems_jffs2_compressor_compress) (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
| | Compress operation. More...
| typedef int(* | rtems_jffs2_compressor_decompress) (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
| | Decompress operation. More...
| typedef void(* | rtems_jffs2_compressor_destroy) (rtems_jffs2_compressor_control *self) |
| | Compressor destroy operation. More...
uint16_t | rtems_jffs2_compressor_rtime_compress (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
| | RTIME compressor compress operation.
int | rtems_jffs2_compressor_rtime_decompress (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
| | RTIME compressor decompress operation.
uint16_t | rtems_jffs2_compressor_zlib_compress (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
| | ZLIB compressor compress operation.
int | rtems_jffs2_compressor_zlib_decompress (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
| | ZLIB compressor decompress operation.
| int | rtems_jffs2_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| | Initialization handler of the JFFS2 file system. More...
The application must provide flash device geometry information and flash device operations in the flash control structure rtems_jffs2_flash_control.
The application can optionally provide a compressor control structure to enable data compression using the selected compression algorithm.
The application must enable JFFS2 support with rtems_filesystem_register() or CONFIGURE_FILESYSTEM_JFFS2 via <rtems/confdefs.h>.
An example mount with a simple memory based flash device simulation follows. The zlib is used for as the compressor.
#define BLOCK_SIZE (32UL * 1024UL)
#define FLASH_SIZE (32UL * BLOCK_SIZE)
typedef struct {
unsigned char area[FLASH_SIZE];
} flash_control;
return (flash_control *) super;
static int flash_read(
uint32_t offset,
flash_control *self = get_flash_control(super);
unsigned char *chunk = &self->area[offset];
memcpy(buffer, chunk, size_of_buffer);
return 0;
static int flash_write(
uint32_t offset,
size_t i;
for (i = 0; i < size_of_buffer; ++i) {
chunk[i] &= buffer[i];
return 0;
static int flash_erase(
uint32_t offset
memset(chunk, 0xff, BLOCK_SIZE);
return 0;
static flash_control flash_instance = {
.super = {
.block_size = BLOCK_SIZE,
.flash_size = FLASH_SIZE,
.read = flash_read,
.write = flash_write,
.erase = flash_erase,
.device_identifier = 0xc01dc0fe
.super = {
.compressor_control = &compressor_instance.super
static void erase_all(void)
memset(&flash_instance.area[0], 0xff, FLASH_SIZE);
void example_jffs2_mount(const char *mount_dir)
int rv;
erase_all();
NULL,
mount_dir,
RTEMS_FILESYSTEM_TYPE_JFFS2,
RTEMS_FILESYSTEM_READ_WRITE,
&mount_data
assert(rv == 0);
◆ rtems_jffs2_compressor_compress
| typedef uint16_t(* rtems_jffs2_compressor_compress) (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
Compress operation.
- Parameters
| [in,out] | self | The compressor control. |
| [in] | data_in | The uncompressed data. |
| [out] | cdata_out | Pointer to buffer with the compressed data. |
| [in,out] | datalen | On entry, the size in bytes of the uncompressed data. On exit, the size in bytes of uncompressed data which was actually compressed. |
| [in,out] | cdatalen | On entry, the size in bytes available for compressed data. On exit, the size in bytes of the actually compressed data. |
- Returns
- The compressor type.
◆ rtems_jffs2_compressor_decompress
| typedef int(* rtems_jffs2_compressor_decompress) (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
- Parameters
| [in] | comprtype | The compressor type. |
| [in] | cdata_in | The compressed data. |
| [out] | data_out | The uncompressed data. |
| [in] | cdatalen | The size in bytes of the compressed data. |
| [in] | datalen | The size in bytes of the uncompressed data. |
- Return values
| 0 | Successful operation. |
| -EIO | An error occurred. Please note that the value is negative. |
| other | All other values are reserved and must not be used. |
◆ rtems_jffs2_compressor_destroy
The compressor destroy operation is called during unmount of the file system instance. It can be used to free the resources associated with the now unused compressor operations.
- Parameters
◆ rtems_jffs2_flash_destroy
The flash destroy operation is called during unmount of the file system instance. It can be used to free the resources associated with the now unused flash control
- Parameters
| [in,out] | self | The flash control. |
◆ rtems_jffs2_flash_erase
This operation must erase one block specified by the offset.
- Parameters
| [in] | offset | The offset to erase from the flash begin in bytes. |
- Return values
◆ rtems_jffs2_flash_read
| typedef int(* rtems_jffs2_flash_read) (rtems_jffs2_flash_control *self, uint32_t offset, unsigned char *buffer, size_t size_of_buffer) |
- Parameters
| [in] | offset | The offset to read from the flash begin in bytes. |
| [out] | buffer | The buffer receiving the data. |
| [in] | size_of_buffer | The size of the buffer in bytes. |
- Return values
◆ rtems_jffs2_flash_write
| typedef int(* rtems_jffs2_flash_write) (rtems_jffs2_flash_control *self, uint32_t offset, const unsigned char *buffer, size_t size_of_buffer) |
- Parameters
| [in] | offset | The offset to write from the flash begin in bytes. |
| [in] | buffer | The buffer containing the data to write. |
- Return values
◆ rtems_jffs2_initialize()
- Parameters
| [in,out] | mt_entry | The mount table entry. |
| [in] | data | The mount options are mandatory for JFFS2 and data must point to a valid rtems_jffs2_mount_data structure used for this file system instance. |
- Return values
| -1 | An error occurred. The errno indicates the error. |
- See also
- mount().
References rtems_jffs2_mount_data::flash_control.
