| RTEMS_STATIC_ASSERT (DT_DIR==(S_IFDIR >> 12), DT_DIR) |
| RTEMS_STATIC_ASSERT (DT_LNK==(S_IFLNK >> 12), DT_LNK) |
| RTEMS_STATIC_ASSERT (DT_REG==(S_IFREG >> 12), DT_REG) |
| RTEMS_STATIC_ASSERT (00400==S_IRUSR, S_IRUSR) |
| RTEMS_STATIC_ASSERT (00200==S_IWUSR, S_IWUSR) |
| RTEMS_STATIC_ASSERT (00100==S_IXUSR, S_IXUSR) |
| RTEMS_STATIC_ASSERT (00040==S_IRGRP, S_IRGRP) |
| RTEMS_STATIC_ASSERT (00020==S_IWGRP, S_IWGRP) |
| RTEMS_STATIC_ASSERT (00010==S_IXGRP, S_IXGRP) |
| RTEMS_STATIC_ASSERT (00004==S_IROTH, S_IROTH) |
| RTEMS_STATIC_ASSERT (00002==S_IWOTH, S_IWOTH) |
| RTEMS_STATIC_ASSERT (00001==S_IXOTH, S_IXOTH) |
| RTEMS_STATIC_ASSERT (0140000==S_IFSOCK, S_IFSOCK) |
| RTEMS_STATIC_ASSERT (0120000==S_IFLNK, S_IFLNK) |
| RTEMS_STATIC_ASSERT (0100000==S_IFREG, S_IFREG) |
| RTEMS_STATIC_ASSERT (0060000==S_IFBLK, S_IFBLK) |
| RTEMS_STATIC_ASSERT (0040000==S_IFDIR, S_IFDIR) |
| RTEMS_STATIC_ASSERT (0020000==S_IFCHR, S_IFCHR) |
| RTEMS_STATIC_ASSERT (0010000==S_IFIFO, S_IFIFO) |
| RTEMS_STATIC_ASSERT (0004000==S_ISUID, S_ISUID) |
| RTEMS_STATIC_ASSERT (0002000==S_ISGID, S_ISGID) |
| RTEMS_STATIC_ASSERT (0001000==S_ISVTX, S_ISVTX) |
| int | rtems_jffs2_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| | Initialization handler of the JFFS2 file system. More...
unsigned char * | jffs2_gc_fetch_page (struct jffs2_sb_info *c, struct jffs2_inode_info *f, unsigned long offset, unsigned long *priv) |
void | jffs2_gc_release_page (struct jffs2_sb_info *c, unsigned char *ptr, unsigned long *priv) |
struct _inode * | jffs2_iget (struct super_block *sb, cyg_uint32 ino) |
void | jffs2_iput (struct _inode *i) |
struct _inode * | jffs2_new_inode (struct _inode *dir_i, int mode, struct jffs2_raw_inode *ri) |
void | jffs2_gc_release_inode (struct jffs2_sb_info *c, struct jffs2_inode_info *f) |
struct jffs2_inode_info * | jffs2_gc_fetch_inode (struct jffs2_sb_info *c, int inum, int unlinked) |
