19 #ifndef _RTEMS_SCORE_THREADMP_H 20 #define _RTEMS_SCORE_THREADMP_H 22 #ifndef _RTEMS_SCORE_THREADIMPL_H 23 # error "Never use <rtems/score/threadmp.h> directly; include <rtems/score/threadimpl.h> instead." 50 uint32_t maximum_proxies
99 #define _Thread_MP_Is_receive(_the_thread) \ 100 ((_the_thread) == _MPCI_Receive_server_tcb) Chain_Node Active
This field is used to manage the set of proxies in the system.
Definition: thread.h:415
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
void _Chain_Extract(Chain_Node *the_node)
Extract the specified node from a chain.
Definition: chainextract.c:27
SCORE_EXTERN Chain_Control _Thread_MP_Active_proxies
Manage the active set MP proxies.
Definition: threadmp.h:83
This is used to manage a chain.
Definition: chain.h:83
SCORE_EXTERN Chain_Control _Thread_MP_Inactive_proxies
Manage the inactive set of MP proxies.
Definition: threadmp.h:90
Objects_Control Object
This field is the object management structure for each thread.
Definition: thread.h:673
This structure defines the Thread Control Block (TCB).
Definition: thread.h:671
Chain_Node Node
This is the chain node portion of an object.
Definition: object.h:234
Thread_Control * _Thread_MP_Find_proxy(Objects_Id the_id)
Removes the MP proxy control block for the specified id from the active chain of proxy control blocks...
Definition: threadmp.c:103
uint32_t States_Control
The following type defines the control block used to manage a thread's state.
Definition: states.h:41
void _Chain_Append(Chain_Control *the_chain, Chain_Node *the_node)
Append a node on the end of a chain.
Definition: chainappend.c:41
Thread_Control * _Thread_MP_Allocate_proxy(States_Control the_state)
Allocate a MP proxy control block from the inactive chain of free proxy control blocks.
Definition: threadmp.c:49
The following defines the control block used to manage each thread proxy.
Definition: thread.h:361
uint32_t Objects_Id
The following type defines the control block used to manage object IDs.
Definition: object.h:122
#define SCORE_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:81
void _Thread_MP_Handler_initialization(uint32_t maximum_proxies)
Initialize MP thread handler.
Definition: threadmp.c:25
MPCI Layer Implementation.
RTEMS_INLINE_ROUTINE void _Thread_MP_Free_proxy(Thread_Control *the_thread)
This routine frees a proxy control block to the inactive chain of free proxy control blocks...
Definition: threadmp.h:107
