#include <rtems.h>#include <rtems/bspIo.h>#include <rtems/score/atomic.h>#include <rtems/score/smpbarrier.h>
| struct | rtems_test_parallel_context |
| Internal context for parallel job execution. More... | |
| struct | rtems_test_parallel_job |
| Basic parallel job description. More... | |
| #define | RTEMS_TEST_INITIAL_EXTENSION { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension } |
| Initial extension for tests. | |
Typedefs | |
| typedef void(* | rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id) |
| Worker task setup handler. More... | |
| void | rtems_test_fatal_extension (rtems_fatal_source source, bool is_internal, rtems_fatal_code code) |
| Fatal extension for tests. | |
| int | rtems_test_begin_with_plugin (rtems_printk_plugin_t printf_func, void *printf_arg) |
| Prints a begin of test message. More... | |
| int | rtems_test_end_with_plugin (rtems_printk_plugin_t printf_func, void *printf_arg) |
| Prints an end of test message. More... | |
| void | rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count) |
| Runs a bunch of jobs in parallel on all processors of the system. More... | |
| const char | rtems_test_name [] |
| Each test must define a test name string. | |
