Test support functions. More...
| struct | rtems_test_parallel_context |
| Internal context for parallel job execution. More... | |
| struct | rtems_test_parallel_job |
| Basic parallel job description. More... | |
| #define | RTEMS_TEST_INITIAL_EXTENSION { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension } |
| Initial extension for tests. | |
Typedefs | |
| typedef void(* | rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id) |
| Worker task setup handler. More... | |
| void | rtems_test_fatal_extension (rtems_fatal_source source, bool is_internal, rtems_fatal_code code) |
| Fatal extension for tests. | |
| int | rtems_test_begin_with_plugin (rtems_printk_plugin_t printf_func, void *printf_arg) |
| Prints a begin of test message. More... | |
| int | rtems_test_end_with_plugin (rtems_printk_plugin_t printf_func, void *printf_arg) |
| Prints an end of test message. More... | |
| void | rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count) |
| Runs a bunch of jobs in parallel on all processors of the system. More... | |
| const char | rtems_test_name [] |
| Each test must define a test name string. | |
| typedef void(* rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id) |
Called during rtems_test_parallel() to optionally setup a worker task before it is started.
| [in] | ctx | The parallel context. |
| [in] | worker_index | The worker index. |
| [in] | worker_id | The worker task identifier. |
| int rtems_test_begin_with_plugin | ( | rtems_printk_plugin_t | printf_func, |
| void * | printf_arg | ||
| [in] | printf_func | The formatted output function. |
| [in,out] | printf_arg | The formatted output function argument. |
References rtems_test_end_with_plugin(), and rtems_test_name.
| int rtems_test_end_with_plugin | ( | rtems_printk_plugin_t | printf_func, |
References rtems_test_name.
Referenced by rtems_test_begin_with_plugin().
| void rtems_test_parallel | ( | rtems_test_parallel_context * | ctx, |
| rtems_test_parallel_worker_setup | worker_setup, | ||
| const rtems_test_parallel_job * | jobs, | ||
| size_t | job_count | ||
The worker tasks inherit the priority of the executing task.
There are SMP barriers before and after the job body.
| [in] | worker_setup | Optional handler to setup a worker task before it is started. |
| [in] | jobs | The table of jobs. |
| [in] | job_count | The count of jobs in the job table. |
