rtems_bdbuf_config Struct Reference
Buffering configuration definition. More...
#include <bdbuf.h>
uint32_t max_read_ahead_blocks
 Number of blocks to read ahead. More...
uint32_t max_write_blocks
 Number of blocks to write at once. More...
rtems_task_priority swapout_priority
 Priority of the swap out task. More...
uint32_t swapout_period
 Period swap-out checks buf timers. More...
uint32_t swap_block_hold
 Period a buffer is held. More...
size_t swapout_workers
 The number of worker threads for the swap-out task. More...
rtems_task_priority swapout_worker_priority
size_t task_stack_size
 Task stack size for swap-out task and worker threads. More...
size_t size
 Size of memory in the cache.
uint32_t buffer_min
 Minimum buffer size. More...
uint32_t buffer_max
 Maximum buffer size supported. More...
rtems_task_priority read_ahead_priority
 Priority of the read-ahead task. More...
See confdefs.h for support on using this structure.
Field Documentation
◆ buffer_max
uint32_t rtems_bdbuf_config::buffer_max
It is also the allocation size.
◆ buffer_min
uint32_t rtems_bdbuf_config::buffer_min
◆ max_read_ahead_blocks
uint32_t rtems_bdbuf_config::max_read_ahead_blocks
◆ max_write_blocks
uint32_t rtems_bdbuf_config::max_write_blocks
◆ read_ahead_priority
rtems_task_priority rtems_bdbuf_config::read_ahead_priority
◆ swap_block_hold
uint32_t rtems_bdbuf_config::swap_block_hold
◆ swapout_period
uint32_t rtems_bdbuf_config::swapout_period
◆ swapout_priority
rtems_task_priority rtems_bdbuf_config::swapout_priority
◆ swapout_worker_priority
rtems_task_priority rtems_bdbuf_config::swapout_worker_priority
◆ swapout_workers
size_t rtems_bdbuf_config::swapout_workers
◆ task_stack_size
size_t rtems_bdbuf_config::task_stack_size
