Timer_Control Struct Reference
The following records define the control block used to manage each timer. More...
#include <timer.h>
Collaboration diagram for Timer_Control:
Collaboration graph
[legend]
Objects_Control Object
 This field is the object management portion of a Timer instance. More...
Watchdog_Control Ticker
 This field is the Watchdog instance which will be the scheduled. More...
Timer_Classes the_class
 This field indicates what type of timer this currently is. More...
Field Documentation
โ—† Object
Objects_Control Timer_Control::Object
Referenced by _Timer_Free(), and rtems_timer_create().
โ—† the_class
Timer_Classes Timer_Control::the_class
Referenced by rtems_timer_create().
โ—† Ticker
Watchdog_Control Timer_Control::Ticker
