Thread Priority Manipulation Routines. More...
#include <rtems/score/cpu.h>
#define | PRIORITY_MINIMUM 0 |
This defines the highest (most important) thread priority. More... | |
#define | PRIORITY_PSEUDO_ISR PRIORITY_MINIMUM |
This defines the priority of pseudo-ISR threads. More... | |
#define | PRIORITY_DEFAULT_MAXIMUM 255 |
This defines the default lowest (least important) thread priority. More... | |
#define | PRIORITY_MAXIMUM rtems_maximum_priority |
This defines the lowest (least important) thread priority. More... | |
Typedefs | |
typedef uint32_t | Priority_Control |
The following type defines the control block used to manage thread priorities. More... | |
uint8_t | rtems_maximum_priority |
This variable contains the configured number of priorities. | |
This include file contains all thread priority manipulation routines. This Handler provides mechanisms which can be used to initialize and manipulate thread priorities.
