RTEMS Run-Time Link Editor Shell Commands. More...
#include <inttypes.h>
#include <rtems/rtl/rtl.h>
#include "rtl-chain-iterator.h"
#include "rtl-shell.h"
#include "rtl-trace.h"
struct | rtems_rtl_shell_cmd_t |
Table of handlers we parse to invoke the command. More... | |
struct | rtems_rtl_obj_summary_t |
Object summary data. More... | |
struct | rtems_rtl_obj_print_t |
Object print data. More... | |
#define | PRIdoff_t PRIo64 |
Typedefs | |
typedef int(* | rtems_rtl_shell_handler_t) (rtems_rtl_data_t *rtl, int argc, char *argv[]) |
The type of the shell handlers we have. | |
int | rtems_rtl_shell_command (int argc, char *argv[]) |
The RTL single shell command contains sub-commands. More... | |
A simple RTL command to aid using the RTL.
int rtems_rtl_shell_command | ( | int | argc, |
char * | argv[] | ||
argc | The argument count. |
argv | Array of argument strings. |
0 | No error. |
