ramdisk.h
1
7 /*
8  * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
9  * Author: Victor V. Vengerov <vvv@oktet.ru>
10  */
11
12 #ifndef _RTEMS_RAMDISK_H
13 #define _RTEMS_RAMDISK_H
14
15
16 #include <rtems.h>
17 #include <rtems/blkdev.h>
18
19 #ifdef __cplusplus
20 extern "C" {
21 #endif
22
39 typedef struct rtems_ramdisk_config {
43  uint32_t block_size;
44
49
54  void *location;
56
64
72
77  rtems_device_major_number major,
78  rtems_device_minor_number minor,
79  void *arg
80 );
81
85 #define RAMDISK_DRIVER_TABLE_ENTRY \
86  { \
87  .initialization_entry = ramdisk_initialize, \
88  RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES \
89  }
90
91 #define RAMDISK_DEVICE_BASE_NAME "/dev/rd"
92
103 typedef struct ramdisk {
107  uint32_t block_size;
108
113
117  void *area;
118
123
127  bool malloced;
128
132  bool trace;
133
138 } ramdisk;
139
140 extern const rtems_driver_address_table ramdisk_ops;
141
142 int ramdisk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp);
143
187  void *area_begin,
188  uint32_t media_block_size,
189  rtems_blkdev_bnum media_block_count,
190  bool trace
191 );
192
193 void ramdisk_free(ramdisk *rd);
194
195 static inline void ramdisk_enable_free_at_delete_request(ramdisk *rd)
196 {
197  rd->free_at_delete_request = true;
198 }
199
212  uint32_t media_block_size,
213  rtems_blkdev_bnum media_block_count,
214  bool trace,
215  const char *disk,
216  dev_t *dev
217 );
218
223 #ifdef __cplusplus
224 }
225 #endif
226
227 #endif
bool initialized
RAM disk is initialized.
Definition: ramdisk.h:122
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:46
rtems_status_code ramdisk_register(uint32_t media_block_size, rtems_blkdev_bnum media_block_count, bool trace, const char *disk, dev_t *dev)
Allocates, initializes and registers a RAM disk.
Definition: ramdisk-register.c:35
uint32_t block_size
RAM disk block size.
Definition: ramdisk.h:43
RAM disk configuration table entry.
Definition: ramdisk.h:39
rtems_ramdisk_config rtems_ramdisk_configuration[]
External reference to the RAM disk configuration table describing each RAM disk in the system...
RAM disk descriptor.
Definition: ramdisk.h:103
struct rtems_ramdisk_config rtems_ramdisk_config
Definition: io.h:52
Description of a disk device (logical and physical disks).
Definition: diskdevs.h:158
ramdisk * ramdisk_allocate(void *area_begin, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, bool trace)
Allocates and initializes a RAM disk descriptor.
Definition: ramdisk-init.c:32
rtems_blkdev_bnum block_num
Number of blocks on this RAM disk.
Definition: ramdisk.h:112
struct ramdisk ramdisk
bool free_at_delete_request
Free the RAM disk at the block device delete request.
Definition: ramdisk.h:137
rtems_status_code
Classic API Status.
Definition: status.h:46
void * location
RAM disk location or NULL if RAM disk memory should be allocated dynamically.
Definition: ramdisk.h:54
void * area
RAM disk memory area.
Definition: ramdisk.h:117
Definition: ramdisk.h:48
bool trace
Trace enable.
Definition: ramdisk.h:132
uint32_t block_size
RAM disk block size, the media size.
Definition: ramdisk.h:107
bool malloced
Indicates if memory is allocated by malloc() for this RAM disk.
Definition: ramdisk.h:127
size_t rtems_ramdisk_configuration_size
External reference the size of the RAM disk configuration table rtems_ramdisk_configuration.
rtems_device_driver ramdisk_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
RAM disk driver initialization entry point.
Definition: ramdisk-config.c:25
Block Device Management.
