Macros | Functions
nodemgmt.c File Reference
#include <linux/kernel.h>
#include <linux/mtd/mtd.h>
#include <linux/compiler.h>
#include <linux/sched.h>
#include "nodelist.h"
#include "debug.h"
Include dependency graph for nodemgmt.c:
#define pr_fmt(fmt)   KBUILD_MODNAME ": " fmt
int jffs2_reserve_space (struct jffs2_sb_info *c, uint32_t minsize, uint32_t *len, int prio, uint32_t sumsize)
int jffs2_reserve_space_gc (struct jffs2_sb_info *c, uint32_t minsize, uint32_t *len, uint32_t sumsize)
struct jffs2_raw_node_refjffs2_add_physical_node_ref (struct jffs2_sb_info *c, uint32_t ofs, uint32_t len, struct jffs2_inode_cache *ic)
 jffs2_add_physical_node_ref - add a physical node reference to the list : superblock info : new node reference to add : length of this physical node More...
void jffs2_complete_reservation (struct jffs2_sb_info *c)
void jffs2_mark_node_obsolete (struct jffs2_sb_info *c, struct jffs2_raw_node_ref *ref)
int jffs2_thread_should_wake (struct jffs2_sb_info *c)
◆ jffs2_add_physical_node_ref()
struct jffs2_raw_node_ref* jffs2_add_physical_node_ref ( struct jffs2_sb_info c,
uint32_t  ofs,
uint32_t  len,
struct jffs2_inode_cache ic
Should only be used to report nodes for which space has been allocated by jffs2_reserve_space.
Must be called with the alloc_sem held.
