Classic Modes Implementation. More...
| RTEMS_INLINE_ROUTINE bool | _Modes_Mask_changed (Modes_Control mode_set, Modes_Control masks) |
| Checks if any of the mode flags in mask are set in mode_set. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_asr_disabled (Modes_Control mode_set) |
| Checks if mode_set says that Asynchronous Signal Processing is disabled. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_preempt (Modes_Control mode_set) |
| Checks if mode_set indicates that preemption is enabled. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_timeslice (Modes_Control mode_set) |
| Checks if mode_set indicates that timeslicing is enabled. More... | |
| RTEMS_INLINE_ROUTINE ISR_Level | _Modes_Get_interrupt_level (Modes_Control mode_set) |
| Gets the interrupt level portion of the mode_set. More... | |
| RTEMS_INLINE_ROUTINE void | _Modes_Set_interrupt_level (Modes_Control mode_set) |
| Sets the current interrupt level to that specified in the mode_set. More... | |
| RTEMS_INLINE_ROUTINE void | _Modes_Change (Modes_Control old_mode_set, Modes_Control new_mode_set, Modes_Control mask, Modes_Control *out_mode_set, Modes_Control *changed) |
| Changes the modes in old_mode_set indicated by mask to the requested values in new_mode_set. More... | |
