ide_part_table.h
1
7 /*
8  * Copyright (C) 2002 OKTET Ltd., St.-Petersburg, Russia
9  *
10  * Author: Konstantin Abramenko <Konstantin.Abramenko@oktet.ru>
11  * Alexander Kukuta <Alexander.Kukuta@oktet.ru>
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  *
17  *****************************************************************************/
18
19 #ifndef _RTEMS_IDE_PART_TABLE_H
20 #define _RTEMS_IDE_PART_TABLE_H
21
22 #include <rtems/chain.h>
23 #include <stdio.h>
24 #include <stdlib.h>
25 #include <string.h>
26 #include <errno.h>
27 #include <sys/ioctl.h>
28 #include <sys/types.h>
29 #include <sys/stat.h>
30 #include <unistd.h>
31 #include <fcntl.h>
32 #include <rtems.h>
33 #include <rtems/blkdev.h>
34 #include <rtems/libio.h>
35 #include <rtems/libio_.h>
36 #include <rtems/bdbuf.h>
37 #include <rtems/seterr.h>
38
39 /* Minor base number for all logical devices */
40 #define RTEMS_IDE_SECTOR_BITS 9
41 #define RTEMS_IDE_SECTOR_SIZE 512
42 #define RTEMS_IDE_PARTITION_DESCRIPTOR_SIZE 16
43 #define RTEMS_IDE_PARTITION_MAX_PARTITION_NUMBER 63
44 #define RTEMS_IDE_PARTITION_MAX_SUB_PARTITION_NUMBER 4
45 #define RTEMS_IDE_PARTITION_DEV_NAME_LENGTH_MAX 16
46
47 #define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA1 0x55
48 #define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA2 0xaa
49 #define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_OFFSET 0x1fe
50 #define RTEMS_IDE_PARTITION_TABLE_OFFSET 0x1be
51 #define RTEMS_IDE_PARTITION_TABLE_SIZE (4 * 16)
52 #define RTEMS_IDE_PARTITION_BOOTABLE_OFFSET 0
53 #define RTEMS_IDE_PARTITION_SYS_TYPE_OFFSET 4
54 #define RTEMS_IDE_PARTITION_START_OFFSET 8
55 #define RTEMS_IDE_PARTITION_SIZE_OFFSET 12
56
57 /*
58  * Conversion from and to little-endian byte order. (no-op on i386/i486)
59  */
60
61 #if (CPU_BIG_ENDIAN == TRUE)
62 # define LE_TO_CPU_U16(v) CPU_swap_u16(v)
63 # define LE_TO_CPU_U32(v) CPU_swap_u32(v)
64 # define CPU_TO_LE_U16(v) CPU_swap_u16(v)
65 # define CPU_TO_LE_U32(v) CPU_swap_u32(v)
66 #else
67 # define LE_TO_CPU_U16(v) (v)
68 # define LE_TO_CPU_U32(v) (v)
69 # define CPU_TO_LE_U16(v) (v)
70 # define CPU_TO_LE_U32(v) (v)
71 #endif
72
73
74 /*
75  * sector_data_t --
76  * corresponds to the sector on the device
77  */
78 typedef struct rtems_sector_data_s
79 {
80  uint32_t sector_num; /* sector number on the device */
81  uint8_t data[RTEMS_ZERO_LENGTH_ARRAY]; /* raw sector data */
83
84
85 /*
86  * Enum partition types
87  * see list at http://ata-atapi.com/hiwtab.htm
88  *
89  * @todo Should these have RTEMS before them.
90  */
91 enum {
92  EMPTY_PARTITION = 0x00,
93  DOS_FAT12_PARTITION = 0x01,
94  DOS_FAT16_PARTITION = 0x04,
95  EXTENDED_PARTITION = 0x05,
96  DOS_P32MB_PARTITION = 0x06,
97  FAT32_PARTITION = 0x0B,
98  FAT32_LBA_PARTITION = 0x0C,
99  FAT16_LBA_PARTITION = 0x0E,
100  DM6_PARTITION = 0x54,
101  EZD_PARTITION = 0x55,
102  DM6_AUX1PARTITION = 0x51,
103  DM6_AUX3PARTITION = 0x53,
104  LINUX_SWAP = 0x82,
105  LINUX_NATIVE = 0x83,
106  LINUX_EXTENDED = 0x85
107 };
108
109
110 /* Forward declaration */
111 struct rtems_disk_desc_s;
112
113 /*
114  * part_desc_t --
115  * contains all neccessary information about partition
116  */
117 typedef struct rtems_part_desc_s {
118  uint8_t bootable; /* is the partition active */
119  uint8_t sys_type; /* type of partition */
120  uint8_t log_id; /* logical number of partition */
121  uint32_t start; /* first partition sector, in absolute
122  * numeration */
123  uint32_t size; /* size in sectors */
124  uint32_t end; /* last partition sector, end = start + size - 1 */
125  struct rtems_disk_desc_s *disk_desc; /* descriptor of disk, partition
126  * contains in */
127  struct rtems_part_desc_s *ext_part; /* extended partition containing this
128  * one */
129
130  /* partitions, containing in this one */
131  struct rtems_part_desc_s *sub_part[RTEMS_IDE_PARTITION_MAX_SUB_PARTITION_NUMBER];
133
134
135
136 typedef struct rtems_disk_desc_s {
137  dev_t dev; /* device number */
138
139  /* device name in /dev filesystem */
140  char dev_name[RTEMS_IDE_PARTITION_DEV_NAME_LENGTH_MAX];
141
142  uint32_t sector_size; /* size of sector */
143  uint32_t sector_bits; /* the base-2 logarithm of sector_size */
144  uint32_t lba_size; /* total amount of sectors in lba address mode */
145  int last_log_id; /* used for logical disks enumerating */
146
147  /* primary partition descriptors */
148  rtems_part_desc_t *partitions[RTEMS_IDE_PARTITION_MAX_PARTITION_NUMBER];
150
151 #ifdef __cplusplus
152 extern "C" {
153 #endif
154
155 /*
156  * rtems_ide_part_table_free --
157  * frees disk descriptor structure
158  *
159  * PARAMETERS:
160  * disk_desc - disc descriptor structure to free
161  *
162  * RETURNS:
163  * N/A
164  */
169  rtems_disk_desc_t *disk_desc
171
172
173 /*
174  * rtems_ide_part_table_get --
175  * reads partition table structure from the device
176  * and creates disk description structure
177  *
178  * PARAMETERS:
179  * dev_name - path to physical device in /dev filesystem
180  * disk_desc - returned disc description structure
181  *
182  * RETURNS:
183  * RTEMS_SUCCESSFUL if success, or -1 and corresponding errno else
184  */
189  const char *dev_name,
190  rtems_disk_desc_t *disk_desc
192
193
194 /*
195  * rtems_ide_part_table_initialize --
196  * initializes logical devices on the physical IDE drive
197  *
198  * PARAMETERS:
199  * dev_name - path to physical device in /dev filesystem
200  *
201  * RETURNS:
202  * RTEMS_SUCCESSFUL if success, or -1 and corresponding errno else
203  */
208  const char *dev_name
210
211 #ifdef __cplusplus
212 }
213 #endif
214
215 #endif /* _RTEMS_IDE_PART_TABLE_H */
Basic IO API.
Data which Ease the Burden of Consistently Setting Errno.
rtems_status_code
Classic API Status.
Definition: status.h:46
Definition: ide_part_table.h:117
Definition: ide_part_table.h:78
rtems_status_code rtems_ide_part_table_initialize(const char *dev_name)
Definition: ide_part_table.c:550
Definition: ide_part_table.h:136
#define RTEMS_COMPILER_DEPRECATED_ATTRIBUTE
Instructs the compiler to issue a warning whenever a variable or function with this attribute will be...
Definition: basedefs.h:186
LibIO Internal Interface.
rtems_status_code rtems_ide_part_table_get(const char *dev_name, rtems_disk_desc_t *disk_desc)
Definition: ide_part_table.c:531
Chain API.
void rtems_ide_part_table_free(rtems_disk_desc_t *disk_desc)
Definition: ide_part_table.c:512
Block Device Management.
Block Device Buffer Management.
