Files | |
| file | mount_prot.h |
| Nfsclient Mount Prot. | |
| file | librtemsNfs.h |
| Public Interface to the NFS Client Library for RTEMS. | |
| file | rpcio.h |
| A Multithreaded RPC/UDP Multiplexor. | |
| #define | RPCIOD_DEFAULT_ID 0xdef10000 |
Typedefs | |
| typedef struct RpcUdpServerRec_ * | RpcUdpServer |
| typedef struct RpcUdpXactRec_ * | RpcUdpXact |
| typedef RpcUdpXact | RpcUdpClnt |
| typedef void * | XdrProcT |
| Mute compiler warnings. | |
| typedef void * | CaddrT |
| typedef struct RpcUdpXactPoolRec_ * | RpcUdpXactPool |
Enumerations | |
| enum | XactPoolGetMode { XactGetFail, XactGetWait, XactGetCreate } |
| void | rpcSetXIDs (uint32_t xid) |
| Sets the XIDs of the RPC transaction hash table. More... | |
| int | rpcUdpInit (void) |
| Initialize the driver. More... | |
| int | rpcUdpCleanup (void) |
| RPC cleanup and stop. More... | |
| int | nfsInit (int smallPoolDepth, int bigPoolDepth) |
| NFS driver interface. More... | |
| int | nfsCleanup (void) |
| Driver cleanup code. More... | |
| int | nfsMountsShow (FILE *f) |
| Dump a list of the currently mounted NFS to a file. More... | |
| int | rtems_nfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Filesystem mount table mount handler. More... | |
| rtems_status_code | rtems_filesystem_resolve_location (char *buf, int len, rtems_filesystem_location_info_t *loc) |
| A utility routine to find the path leading to a rtems_filesystem_location_info_t node. More... | |
| int | nfsSetTimeout (uint32_t timeout_ms) |
| Set the timeout (initial default: 10s) for NFS and mount calls. More... | |
| uint32_t | nfsGetTimeout (void) |
| Read current timeout (in milliseconds) | |
| enum clnt_stat | rpcUdpServerCreate (struct sockaddr_in *paddr, rpcprog_t prog, rpcvers_t vers, u_long uid, u_long gid, RpcUdpServer *pclnt) |
| void | rpcUdpServerDestroy (RpcUdpServer s) |
| int | rpcUdpStats (FILE *f) |
| Dump statistics to a file (stdout if NULL);. More... | |
| enum clnt_stat | rpcUdpClntCreate (struct sockaddr_in *psaddr, rpcprog_t prog, rpcvers_t vers, u_long uid, u_long gid, RpcUdpClnt *pclnt) |
| void | RpcUdpClntDestroy (RpcUdpClnt clnt) |
| enum clnt_stat | rpcUdpClntCall (RpcUdpClnt clnt, u_long proc, XdrProcT xargs, CaddrT pargs, XdrProcT xres, CaddrT pres, struct timeval *timeout) |
| RpcUdpXact | rpcUdpXactCreate (u_long program, u_long version, u_long size) |
| void | rpcUdpXactDestroy (RpcUdpXact xact) |
| enum clnt_stat | rpcUdpSend (RpcUdpXact xact, RpcUdpServer srvr, struct timeval *timeout, u_long proc, xdrproc_t xres, caddr_t pres, xdrproc_t xargs, caddr_t pargs,...) |
| Send a transaction. | |
| enum clnt_stat | rpcUdpRcv (RpcUdpXact xact) |
| Wait for a transaction to complete. | |
| enum clnt_stat | rpcUdpCallRp (struct sockaddr_in *pserver_addr, u_long prog, u_long vers, u_long proc, XdrProcT xargs, CaddrT pargs, XdrProcT xres, CaddrT pres, u_long uid, u_long gid, struct timeval *timeout) |
| RpcUdpXactPool | rpcUdpXactPoolCreate (rpcprog_t prog, rpcvers_t version, int xactsize, int poolsize) |
| void | rpcUdpXactPoolDestroy (RpcUdpXactPool pool) |
| RpcUdpXact | rpcUdpXactPoolGet (RpcUdpXactPool pool, XactPoolGetMode mode) |
| void | rpcUdpXactPoolPut (RpcUdpXact xact) |
| rtems_task_priority | rpciodPriority |
| RPCIO driver interface. More... | |
| int nfsCleanup | ( | void | ) |
| 0 | on success, nonzero if still in use |
| int nfsInit | ( | int | smallPoolDepth, |
| int | bigPoolDepth | ||
Initialize the NFS driver.
The RPCIO driver must have been initialized prior to calling this.
Note, called in nfsfs initialise when mount is called with defaults.
ARGS: depth of the small and big transaction pools, i.e. how many transactions (buffers) should always be kept around.
(If more transactions are needed, they are created and destroyed on the fly).
Supply zero values to have the driver chose reasonable defaults.
| 0 | Successful operation. |
| -1 | An error occurred. The errno is set to indicate the error. |
| int nfsMountsShow | ( | FILE * | f | ) |
Dump a list of the currently mounted NFS to a file (stdout is used in case f==NULL)
| int nfsSetTimeout | ( | uint32_t | timeout_ms | ) |
| 0 | on success, nonzero if the requested timeout is less than a clock tick or if the system clock rate cannot be determined. |
| void rpcSetXIDs | ( | uint32_t | xid | ) |
The active RPC transactions are stored in a hash table. Each table entry contains the XID of its corresponding transaction. The XID consists of two parts. The lower part is determined by the hash table index. The upper part is incremented in each send operation.
This function sets the upper part of the XID in all hash table entries. This can be used to ensure that the XIDs are not reused in a short interval for example during a boot process or after resets.
| [in] | xid | The upper part is used to set the upper XID part of the hash table entries. |
| int rpcUdpCleanup | ( | void | ) |
References rtems_build_name, RTEMS_DEFAULT_ATTRIBUTES, and rtems_semaphore_create().
| int rpcUdpInit | ( | void | ) |
Note, called in nfsfs initialise when mount is called.
| 0 | on success, -1 on failure |
| int rpcUdpStats | ( | FILE * | f | ) |
| 0 | for convenience |
| rtems_status_code rtems_filesystem_resolve_location | ( | char * | buf, |
| int | len, | ||
| rtems_filesystem_location_info_t * | loc | ||
This should really be present in libcsupport...
| [in] | 'loc' | and a buffer 'buf' (length 'len') to hold the path. |
| [out] | path | copied into 'buf' |
| 0 | on success, RTEMS error code on error. |
| int rtems_nfs_initialize | ( | rtems_filesystem_mount_table_entry_t * | mt_entry, |
| const void * | data | ||
Filesystem mount table mount handler. Do not call, use the mount call.
| rtems_task_priority rpciodPriority |
If you need RPCIO for other purposes than NFS you may want to include <rpcio.h> #include "rpcio.h" Priority of daemon; may be setup prior to calling rpcUdpInit(); otherwise the network task priority from the rtems_bsdnet_config is used...
