CPU Usage Report. More...
Files | |
file | cpuusagedata.c |
CPU Usage DataCPU Usage Reporter - Shared Data. | |
file | cpuusagereport.c |
CPU Usage Report. | |
file | cpuusagereset.c |
CPU Usage Reset. | |
file | cpuusagetop.c |
CPU Usage Top. | |
void | rtems_cpu_usage_report_with_plugin (void *context, rtems_printk_plugin_t handler) |
void | rtems_cpu_usage_report (void) |
Report CPU usage. More... | |
void | rtems_cpu_usage_top_with_plugin (void *context, rtems_printk_plugin_t print) |
CPU usage Top plugin. More... | |
void | rtems_cpu_usage_top (void) |
CPU usage top. More... | |
void | rtems_cpu_usage_reset (void) |
Reset CPU usage. More... | |
Timestamp_Control | CPU_usage_Uptime_at_last_reset |
CPU Usage Report.
This include file contains information necessary to utilize and install the cpu usage reporting mechanism.
void rtems_cpu_usage_report | ( | void | ) |
Report CPU usage.
CPU Usage Reporter
void rtems_cpu_usage_reset | ( | void | ) |
Reset CPU usage.
CPU Usage Reporter
void rtems_cpu_usage_top | ( | void | ) |
void rtems_cpu_usage_top_with_plugin | ( | void * | context, |
rtems_printk_plugin_t | |||
Report CPU Usage in top format to to a print plugin.
Referenced by rtems_cpu_usage_top().
