Files | |
| file | timecounter.h |
| Timecounter API. | |
| struct | rtems_timecounter_simple |
| Simple timecounter to support legacy clock drivers. More... | |
| #define | RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER 100 |
| Timecounter quality for the clock drivers. More... | |
Typedefs | |
| typedef void | rtems_timecounter_simple_at_tick(rtems_timecounter_simple *tc) |
| At tick handling done under protection of the timecounter lock. | |
| typedef uint32_t | rtems_timecounter_simple_get(rtems_timecounter_simple *tc) |
| Returns the current value of a simple timecounter. | |
| typedef bool | rtems_timecounter_simple_is_pending(rtems_timecounter_simple *tc) |
| Returns true if the interrupt of a simple timecounter is pending, and false otherwise. | |
| #define RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER 100 |
Timecounter with higher quality value are used in favour of those with lower quality value.
| RTEMS_INLINE_ROUTINE void rtems_timecounter_install | ( | struct timecounter * | tc | ) |
Installs the timecounter.
The timecounter structure must contain valid values in the fields tc_get_timecount, tc_counter_mask, tc_frequency and tc_quality. All other fields must be zero initialized.
| [in] | tc | The timecounter. |
Below is an exemplary code snippet that shows the adjustable parameters and the following call of the install routine.
References _Timecounter_Install().
| RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_downcounter_get | ( | struct timecounter * | tc_base, |
| rtems_timecounter_simple_get | get, | ||
| rtems_timecounter_simple_is_pending | is_pending | ||
Gets the simple timecounter value mapped to its binary frequency domain for downcounters.
| [in] | tc | The simple timecounter. |
| [in] | get | The method to get the value of the simple timecounter. |
| [in] | is_pending | The method which indicates if the interrupt of the simple timecounter is pending. |
| RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_downcounter_tick | ( | rtems_timecounter_simple * | tc, |
| rtems_timecounter_simple_at_tick | at_tick | ||
Performs a simple timecounter tick for downcounters.
| [in] | at_tick | The method to perform work under timecounter lock protection at this tick, e.g. clear a pending flag. |
References _Timecounter_Acquire, _Timecounter_Tick_simple(), and rtems_timecounter_simple_scale().
| void rtems_timecounter_simple_install | ( | rtems_timecounter_simple * | tc, |
| uint32_t | frequency_in_hz, | ||
| uint32_t | timecounter_ticks_per_clock_tick, | ||
| timecounter_get_t * | get_timecount | ||
Initializes and installs a simple timecounter.
A simple timecounter can be used if the hardware provides no free running counter or only the module used for the clock tick is available. The period of the simple timecounter equals the clock tick interval. The interval is scaled up to the next power of two.
| [in] | tc | Zero initialized simple timecounter. |
| [in] | frequency_in_hz | The timecounter frequency in Hz. |
| [in] | timecounter_ticks_per_clock_tick | The timecounter ticks per clock tick. |
| [in] | get_timecount | The method to get the current time count. |
| RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_scale | ( | const rtems_timecounter_simple * | tc, |
| uint32_t | value | ||
Maps a simple timecounter value into its binary frequency domain.
| [in] | value | The value of the simple timecounter. |
Referenced by rtems_timecounter_simple_downcounter_tick(), and rtems_timecounter_simple_upcounter_tick().
| RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_upcounter_get | ( | struct timecounter * | tc_base, |
Gets the simple timecounter value mapped to its binary frequency domain for upcounters.
| RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_upcounter_tick | ( | rtems_timecounter_simple * | tc, |
Performs a simple timecounter tick for upcounters.
| RTEMS_INLINE_ROUTINE void rtems_timecounter_tick | ( | void | ) |
Performs a timecounter tick.
References _Timecounter_Tick().
