Files | Data Structures | Functions | Variables
Device Only File System
This structure defines the type of device table. More...
Collaboration diagram for Device Only File System:
file  devclose.c
 Maps Close Operation to rtems_io_close.
file  devfs_eval.c
 Evaluate Patch.
file  devfs_init.c
 Creates the Main Device Table.
file  devfs_mknod.c
 Creates an item in the main device table.
file  devfs_show.c
 Retrieves and Prints all the Device Registered in System.
file  devioctl.c
 Maps ioctl Operation to rtems_io_ioctl.
file  devopen.c
 Maps Open Operation to rtems_io_open.
file  devstat.c
 Gets the Device File Information.
file  devwrite.c
 Writes Operation to rtems_io_write.
struct  devFS_node
 Per Device Node Control Structure. More...
struct  devFS_data
void devFS_eval_path (rtems_filesystem_eval_path_context_t *ctx)
 Evaluate Path.
int devFS_open (rtems_libio_t *iop, const char *pathname, int oflag, mode_t mode)
 Maps Open Operation to rtems_io_open. More...
int devFS_close (rtems_libio_t *iop)
 Maps Close Operation to rtems_io_close. More...
ssize_t devFS_read (rtems_libio_t *iop, void *buffer, size_t count)
 Maps Read Operation to rtems_io_read. More...
ssize_t devFS_write (rtems_libio_t *iop, const void *buffer, size_t count)
 Writes Operation to rtems_io_write. More...
int devFS_ioctl (rtems_libio_t *iop, ioctl_command_t command, void *buffer)
 Maps ioctl Operation to rtems_io_ioctl. More...
int devFS_stat (const rtems_filesystem_location_info_t *loc, struct stat *buf)
 Gets the Device File Information. More...
int devFS_mknod (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
 Creates an item in the main device table. More...
int devFS_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Creates the Main Device Table. More...
void devFS_Show (void)
 Retrieves and Prints all the Device Registered in System. More...
const rtems_filesystem_operations_table devFS_ops
 The following defines the device-only filesystem operating operations.
const rtems_filesystem_file_handlers_r devFS_file_handlers
 The following defines the device-only filesystem operating handlers.
◆ devFS_close()
int devFS_close ( rtems_libio_t iop)
This handler maps close operation to rtems_io_close.
Parameters
iopThis is the RTEMS's internal representation of file
Return values
thesame as close
◆ devFS_initialize()
int devFS_initialize ( rtems_filesystem_mount_table_entry_t mt_entry,
const void *  data
This routine is invoked upon rtems filesystem initialization. It is responsible for creating the main device table, initializing it to a known state, and set device file operation handlers. After this, the device-only filesytem is ready for use
Parameters
mt_entryThe filesystem mount table entry.
dataFilesystem specific data.
Return values
uponsuccess, this routine returns 0; otherwise it returns -1 and errno is set to proper value. The only error is when malloc failed, and errno is set to NOMEM.
References devFS_file_handlers, and devFS_ops.
◆ devFS_ioctl()
int devFS_ioctl ( rtems_libio_t iop,
void *  buffer
This handler maps ioctl operation to rtems_io_ioctl.
Parameters
commandio control command
bufferio control parameters
Return values
Onsuccessful, this routine returns total bytes written. On error it returns -1 and errno is set to proper value.
◆ devFS_mknod()
int devFS_mknod ( const rtems_filesystem_location_info_t parentloc,
const char *  name,
size_t  namelen,
mode_t  mode,
dev_t  dev
This routine is invoked upon registration of a new device file. It is responsible for creating a item in the main device table. This routine searches the device table in sequential order, when found a empty slot, it fills the slot with proper values.
See also
rtems_filesystem_mknod_t.
◆ devFS_open()
int devFS_open ( rtems_libio_t iop,
const char *  pathname,
int  oflag,
mode_t  mode
This handler maps open operation to rtems_io_open.
Parameters
iopThis is the RTEMS's internal representation of file.
pathnamea null-terminated string that starts with /dev.
oflagaccess flags
modeaccess mode
Return values
thesame as open
References devFS_node::major, devFS_node::minor, and rtems_deviceio_open().
◆ devFS_read()
ssize_t devFS_read ( rtems_libio_t iop,
void *  buffer,
size_t  count
This handler maps read operation to rtems_io_read.
Parameters
buffermemory location to store read data
counthow many bytes to read
Return values
Onsuccessful, this routine returns total bytes read. On error it returns -1 and errno is set to proper value.
◆ devFS_Show()
void devFS_Show ( void  )
This routine retrieves all the device registered in system, and prints out their detail information. For example, on one system, devFS_show will print out following message:
/dev/console 0 0
/dev/clock 1 0
/dev/tty0 0 0
/flash 2 0
This routine is intended for debugging, and can be used by shell program to provide user with the system information.
◆ devFS_stat()
int devFS_stat ( const rtems_filesystem_location_info_t loc,
struct stat *  buf
This handler gets the device file information. This routine only set the following member of struct stat:
  • st_dev: device number
  • st_mode: device file creation mode, only two mode are accepted:
    • S_IFCHR: character device file
    • S_IFBLK: block device file
Parameters
loccontains filesystem access information
bufbuffer to hold the device file's information
Return values
Onsuccessful, this routine returns 0. On error it returns -1 and errno is set to proper value.
◆ devFS_write()
ssize_t devFS_write ( rtems_libio_t iop,
const void *  buffer,
size_t  count
This handler maps write operation to rtems_io_write.
Parameters
bufferdata to be written
counthow many bytes to write
Return values
