Files | |
| file | dpmemimpl.h |
| Dual Ported Memory Manager Implementation. | |
| #define | RTEMS_DPMEM_EXTERN extern |
| This constant is defined to extern most of the time when using this header file. More... | |
| void | _Dual_ported_memory_Manager_initialization (void) |
| Dual Ported Memory Manager Initialization. More... | |
| RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * | _Dual_ported_memory_Allocate (void) |
| Allocates a port control block from the inactive chain of free port control blocks. More... | |
| RTEMS_INLINE_ROUTINE void | _Dual_ported_memory_Free (Dual_ported_memory_Control *the_port) |
| Frees a port control block to the inactive chain of free port control blocks. More... | |
| RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * | _Dual_ported_memory_Get (Objects_Id id, Objects_Locations *location) |
| Maps port IDs to port control blocks. More... | |
| RTEMS_DPMEM_EXTERN Objects_Information | _Dual_ported_memory_Information |
| Define the internal Dual Ported Memory information The following define the internal Dual Ported Memory information. | |
| #define RTEMS_DPMEM_EXTERN extern |
However by defining it to nothing, the data declared in this header file can be instantiated. This is done in a single per manager file.
| RTEMS_INLINE_ROUTINE Dual_ported_memory_Control* _Dual_ported_memory_Allocate | ( | void | ) |
This routine allocates a port control block from the inactive chain of free port control blocks.
References _Objects_Allocate().
| RTEMS_INLINE_ROUTINE void _Dual_ported_memory_Free | ( | Dual_ported_memory_Control * | the_port | ) |
This routine frees a port control block to the inactive chain of free port control blocks.
References _Objects_Free(), and Dual_ported_memory_Control::Object.
| RTEMS_INLINE_ROUTINE Dual_ported_memory_Control* _Dual_ported_memory_Get | ( | Objects_Id | id, |
| Objects_Locations * | location | ||
This function maps port IDs to port control blocks. If ID corresponds to a local port, then it returns the_port control pointer which maps to ID and location is set to OBJECTS_LOCAL. Global ports are not supported, thus if ID does not map to a local port, location is set to OBJECTS_ERROR and the_port is undefined.
References _Objects_Get().
Referenced by rtems_port_delete(), rtems_port_external_to_internal(), and rtems_port_internal_to_external().
| void _Dual_ported_memory_Manager_initialization | ( | void | ) |
This routine performs the initialization necessary for this manager.
References _Dual_ported_memory_Information, and _Objects_Initialize_information().
