#include <ctype.h>
#include <inttypes.h>
#include <rtems/capture-cli.h>
#include <rtems/captureimpl.h>
#include <rtems/monitor.h>
#include <rtems/cpuuse.h>
struct | rtems_capture_cli_triggers_s |
#define | RC_UNUSED __attribute__((unused)) |
#define | RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS (20) |
#define | RTEMS_CAPTURE_CLI_TRIGGERS_NUM (sizeof (rtems_capture_cli_triggers) / sizeof (rtems_capture_cli_triggers_t)) |
Typedefs | |
typedef struct rtems_capture_cli_triggers_s | rtems_capture_cli_triggers_t |
typedef enum rtems_capture_cli_trig_state_e | rtems_capture_cli_trig_state_t |
Enumerations | |
enum | rtems_capture_cli_trig_state_e { trig_type, trig_to, trig_from_from, trig_from } |
rtems_status_code | rtems_capture_cli_init (rtems_capture_timestamp timestamp) |
rtems_capture_cli_init More... | |
rtems_status_code rtems_capture_cli_init | ( | rtems_capture_timestamp | timestamp | ) |
This function initialises the command line interface to the capture engine.
