BSP and Device Driver Development Guide
The boot_card() is the first C code invoked. This file is the
core component in the RTEMS BSP Initialization Framework and provides
the proper sequencing of initialization steps for the BSP, RTEMS and
device drivers. All BSPs use the same shared version of boot_card()
which is located in the following file:
c/src/lib/libbsp/shared/bootcard.c
The boot_card() routine performs the following functions:
bsp_get_work_area function to obtain
information on the amount and location of BSP RAM that is available to
be allocated to the C Program Heap and RTEMS Workspace. If the amount
of memory available for the RTEMS Workspace is less than that required
by the application (e.g. rtems_configuration_get_work_space_size(),
then a message is printed using printk, bsp_cleanup is
invoked, and -1 is return to the assembly language start code. BSPs which
use this memory allocation functionality in bootcard.c
must invoke the RTEMS specific autoconf macro
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION in the BSP's
configure.ac file.
bsp_start() which is
written in C and thus able to perform more advanced initialization.
Often MMU and bus initialization occurs here.
rtems_initialize_data_structures() to initialize the RTEMS
executive to a state where objects can be created but tasking is not
enabled.
bsp_pretasking_hook. On
most BSPs which utilize the framework, this routine does nothing.
RTEMS_DEBUG is enabled, then the RTEMS debug mask level
is inialized appropriately.
rtems_initialize_before_drivers() to initialize the MPCI Server
thread in a multiprocessor configuration and execute API specific
extensions.
bsp_predriver_hook. For
most BSPs, the implementation of this routine does nothing. However,
on some BSPs, required subsystems which utilize the C Library
(e.g. malloc in particular) may be initialized at this point.
rtems_initialize_device_drivers() to initialize the statically
configured set of device drivers in the order they were specified in
the Configuration Table.
bsp_postdriver_hook. For
most BSPs, the implementation of this routine does nothing. However, some
BSPs use this hook and perform some initialization which must be done at
this point in the initialization sequence. This is the last opportunity
for the BSP to insert BSP specific code into the initialization sequence.
rtems_initialize_start_multitasking() which starts multitasking and context switches to the first task. boot_card() will not return until the application is shutdown. As part of this sequence the following actions occur:
boot_card() from RTEMS, it invokes the BSP specific
routine bsp_cleanup() to perform any necessary board specific
shutdown actions.
That's it. We just went through the entire sequence.
