BSP and Device Driver Development Guide
This is the first BSP specific C routine to execute during system initialization. This routine often performs required fundamental hardware initialization such as setting bus controller registers that do not have a direct impact on whether or not C code can execute. The source code for this routine is usually found in the following file:
c/src/lib/libbsp/CPU/BSP/startup/bspstart.c
On older BSPs not using boot_card()'s support for allocating memory
to the C Program Heap and RTEMS Workspace, one of the most important
functions performed by this routine is determining where the RTEMS
Workspace is to be located in memory. All RTEMS objects and task stacks
will be allocated from this Workspace. The RTEMS Workspace is distinct
from the application heap used for malloc(). Many BSPs place
the RTEMS Workspace area at the end of RAM although this is certainly
not a requirement.
After completing execution, this routine returns to the boot_card()
routine.
