BSP and Device Driver Development Guide
The assembly language code in the directory start is the first part
of the application to execute. It is responsible for initializing the
processor and board enough to execute the rest of the BSP. This includes:
.bss
The general rule of thumb is that the start code in assembly should do the minimum necessary to allow C code to execute to complete the initialization sequence.
The initial assembly language start code completes its execution by
invoking the shared routine boot_card().
The label (symbolic name) associated with the starting address of the
program is typically called start. The start object file is the
first object file linked into the program image so it is ensured that
the start code is at offset 0 in the .text section. It is the
responsibility of the linker script in conjunction with the compiler
specifications file to put the start code in the correct location in
the application image.
